Noob question. 3.9l EA seems to be missfiring.
Page 1 of 1 [ 10 posts ]
 Post subject: Noob question. 3.9l EA seems to be missfiring.
Posted: Thu Dec 10, 2015 10:21 am
Ride: 1989 Ford NA Fairlane
I'd like to start off by saying when it comes to mechanicals i don't really know much at all. In saying that here goes lol.
So my car has devoleped what i believe to be a missfire as of late.
When idling it seems as though the engine is shaking randomly every 5 or so seconds.
I'm uploading a video to youtube at the moment and ill pay a link as soon as it's up.
I've changed the spark plugs and while it starts easier the problem still remains.
Also, on what may or may not be an unrelated note.
This pulley ( which i believe is a tensioner ) has fallen off (bolt broke).
Could this be the source of the problem?
NA Fairlane Build Thread
the-garage-f53/exqsme-s-na-fairlane-t117388.html
 Post subject: Re: Noob question. 3.9l EA seems to be missfiring.
Posted: Thu Dec 10, 2015 10:58 am
Youtube vid of the car running funny.
https://youtu.be/8WoePH--Azg
Posted: Thu Dec 17, 2015 1:27 pm
Ride: ea falcon
Dissy cap and rotor button. Make sure to replace them with a Bosch part.. The fuel miser stuff is rubbish.
Those leads look like they've had a long life too.
Make sure base timing ignition is set to the "IGN" mark.
The pulley is just an idler for the air-con..
EA falcon(S-Pac) AU engine and injector's, EL BBM conversion,K&N pod,EL ECU,T5 5speed,EL Streering rack, EL Brake system, Extractor's 2 1/2in high flow cat, through 2 1/2in mandrel bent pipe with Lukey Performance muffler
Posted: Thu Dec 17, 2015 2:28 pm
That involves pulling almost everything off the left side of the block doesn't it? :(
Posted: Thu Dec 17, 2015 2:58 pm
Ride: ea falcon
Nah. It's tight but with some persistance you can can the job done.. Tho it could be a good time to just replace the intake gasket..
2 birds 1 stone an all that.
Posted: Sun Dec 20, 2015 1:17 pm
Where can I find the IGN mark? Or is the a guide or anything on how to change it over properly?
Posted: Sun Dec 20, 2015 1:36 pm
Ride: EF Fairmont
It should be marked on the dizzy.
Posted: Sun Dec 20, 2015 1:46 pm
Sweet. Thanks for the quick reply. Will be doing this as well as getting new tires tomorrow. Woo
Posted: Mon Dec 21, 2015 1:17 pm
Ride: ea falcon
What i meant was to make sure your ignition timing is set correctly one you get the previous jobs done.
In your second image you can see the TDC and IGN timing marks.
The timing needs to be correctly set at the IGN mark.
Posted: Mon Dec 21, 2015 1:21 pm
Ok. Thank you for the Clarification. I'll go through the book and follow the instructions in there. Thanks!
It is currently Sun May 18, 2025 7:05 pm All times are UTC + 11 hours
