ashford |
If anyone can help ? The ABS warning light comes on my BF wagon , it isn't usually on when you first start to drive, but comes on after say 5 mins, also how do you remove the brake light switches from the pedal box please
Robert_au |
{USERNAME} wrote: If anyone can help ? The ABS warning light comes on my BF wagon , it isn't usually on when you first start to drive, but comes on after say 5 mins, also how do you remove the brake light switches from the pedal box please Could be anything from a dirty/faulty sensor to low voltage in your electrical system. best bet is getting it scanned for fault codes. you could try giving all the wheel sensors a clean, they do cake up with mud and crud. what do you need to remove the brake switch for? it just twists a little bit then pops out kind of like a bayonet fitting.
_________________ Current Ride |
Users browsing this forum: Google Adsense [Bot] and 50 guests |
