car10001 |
Hi
Just a question is it possible to get 6 ea-ed/el single coils and wire them as a ef/au coil pack would be (one + & 3 triggers) Will wiring 6 single coils in place of a ef coil pack work with a ef/au ecu Looked at wiring diagram and looks like all + are wired together and there's 3- triggers one per 2 cyl Thanks |
kimboxr6 |
Why would you want to do that?
_________________ ef2 fairmont ghia tickford 6 |
93EB |
Age: 46 Posts: 2484 Joined: 6th Oct 2005 Ride: 93EB Fairmont / BA Falcon XR6T Location: Western Sydney |
Buy a BA. They have 6 seperate coils..
_________________ 93 EB II Fairmon8 with 17' EL GT's / Clear indicators / H.I.Ds / Sports exhaust / Lowered 2' / K&N / XR6 ECU. |
TedW |
can you - yes
should you - no you would need to connect with 2 coils to fire at same time (x 3 banks of) as ef/au use waste spark system (one plug fires on compression stroke other on exhaust stroke)extra load would cause weak spark and eventually cause ECU failure...................... |
Users browsing this forum: Google Adsense [Bot] and 41 guests |
