auwpn |
hey guys
i am getting an exhaust system fitted at JMM hich will include: 2 1/2 inch mandrel bent exhaust, high flow cat with JMM extractors and am gunna chuck in an automatic adaptive shift kit was wondering if its worth getting a K&N Air Filter rather than a JMM air filter?? anyone recommend these filters and how would it go with the system ive got here?? thanx guys
_________________ AU Falcon Forte, Auto I6, 2.5" Redback Mandrel Bent Exhaust, Genie Extractors, BMC Panel Filter, Race Shift Kit, XR8 Snorkel, King Spring Superlows, 17" ROH Mags, Pedders Shocks, Tinted Windows, Blue In-Car Neons, In-Car Bluetooth, Black XR Interior, Momo Steering Wheel, Clarion Premium Sound |
twr7cx |
What's the cost of a JMM one?
I mean K&N are a huge brand and that, so if there cheaper than the JMM ones' I'd go with them as there's no question on there quality or anything. |
auwpn |
the JMM air filter is $190 - but im happy to pay a bit extra if the K&N Filter will give me more satisfaction
Gaz |
the K&N will be cheaper than 190 thats for sure
auwpn |
who in Melbourne sells K&N Parts??
nathen |
mate go the k and n .a lot cheaper than the other 1
Slick |
try uni-filter, 1% below K&N in flow but far more superior in filtration. good thing about uni is you can remove one of the two foam{fine} & leave the a*** form for the drags. it'll probably flow better.
Johnson stroker |
who makes the JMM one? there are only so many top notch filter out there.. from memory I paid about $110 for mine for an ef falcon.. I'm thinking maybe a BMC in JMM package?? but that for of money is HUGE for a filter. is it a panel filter or a pod filter?
v8fordman351 |
{USERNAME} wrote: try uni-filter, 1% below K&N in flow but far more superior in filtration. good thing about uni is you can remove one of the two foam{fine} & leave the a*** form for the drags. it'll probably flow better. ive heard the uni filters because the are oiled dirty the air flow meter pretty bad my k&n did when it was new then i cleaned it and its been fine goes harder and uses 1/2 the fuel
Slick |
{USERNAME} wrote: {USERNAME} wrote: try uni-filter, 1% below K&N in flow but far more superior in filtration. good thing about uni is you can remove one of the two foam{fine} & leave the a*** form for the drags. it'll probably flow better. ive heard the uni filters because the are oiled dirty the air flow meter pretty bad my k&n did when it was new then i cleaned it and its been fine goes harder and uses 1/2 the fuel
v8fordman351 |
{USERNAME} wrote: {USERNAME} wrote: {USERNAME} wrote: try uni-filter, 1% below K&N in flow but far more superior in filtration. good thing about uni is you can remove one of the two foam{fine} & leave the a*** form for the drags. it'll probably flow better. ive heard the uni filters because the are oiled dirty the air flow meter pretty bad my k&n did when it was new then i cleaned it and its been fine goes harder and uses 1/2 the fuel |
Slick |
{USERNAME} wrote: {USERNAME} wrote: {USERNAME} wrote: {USERNAME} wrote: try uni-filter, 1% below K&N in flow but far more superior in filtration. good thing about uni is you can remove one of the two foam{fine} & leave the a*** form for the drags. it'll probably flow better. ive heard the uni filters because the are oiled dirty the air flow meter pretty bad my k&n did when it was new then i cleaned it and its been fine goes harder and uses 1/2 the fuelSorry dude! So you mean: when you had the K&N filter it dirtied the air flow meter. So you brought yourself a uni-filter and now it goes harder and uses 1/2 the fuel. is that correct, or is it the other way round.
v8fordman351 |
sorry mate ive NEVER had a finer filter except on my old gas reaserch xd but ive heard on efi cars its a prob but with my k&n its seemed that when it was new it was slightly over oiled cause after about 2 tanks of fuel it started useing heaps,then a guy showed me how to pull the element out of the air flow and clean the oil film out of it now its awsome
theblackone |
{USERNAME} wrote: the JMM air filter is $190 - but im happy to pay a bit extra if the K&N Filter will give me more satisfaction
are you sure its just the FILTER for $190? i thought when it says "hi flow intake mods" they are change the intake piping aswell, and puttin in the air filter. I think i remember msging someone that had a DEV 3 kit but cant remeber if he said anything about the hi flow intake mod. Check up on that to see if it is just the FILTER for $190 or anything extra
_________________ SIGNATURE REMOVED - REFER TO FORUM GUIDELINES! |
twr7cx |
JMM's high flow intake piping is a lot more than $190.00!
I'd go the K&N, because a. it's a fair bit cheaper ($110ish retail - most autp stpres sell them - Autobarn, Repco, etc.), and b. because there all huge brands I don't think any are really significantly superior, and the notice between a K&N filter and stock is near nothing, so the notice between a K&N and another expensive high flow is probably near on nonexistant (on near stock cars). |
Users browsing this forum: No registered users and 47 guests |
