scotty2611 |
I have a EBII without smartlock,
I have a smartlock digital signal override module so that fixes the smartlock But I have the wiring loom from the EL inc ECU, From the ECU to the BBM that goes throgh the fire wall, With this loom it includes the Trans loom, The EB loom runs across to the drivers side and includes the o2 sensor and also goes to the battery, plus other conections, Which loom do I use, EB or EL and how do i go about the modification of the looms ( What to keep What to loose ) All Help would be great Thanks Scotty2611
_________________ EB 2,Turbo EL Motor, Momo Wheel, Cam, Fuel preasure reg, LSD, Color coded boot garnish 17" wheels, Lowered, Shift kit, Slotted & cross Drilled Brakes, AU fuel injectors, & more to come |
dvyvan |
ok sorry but i cant help you however i was wondering where did you get this smartlock bypass and what price....as im looking for something along these lines
_________________ Automatics only come in assult riffles
xpression |
if your gonna goto the trouble of fitting half an EL loom, have u considered going the hole hog and fitting an entire EL loom incl the dash loom and dash? more work but well worth it, and u get smartlock than
scotty2611 |
Is the dash Straight boltp or heaps of mods
