Seannyb |
Calling EVERYONE who knows anything about installing an EL BBM into an ED.
Are the injectors the same size / flow rate. Does the wiring loom plug straight in, am i going to have any trouble? Any and all help would be greatly appreciated. Thanks.
_________________ Car Killer. |
JOSE |
injectors are the same, wiring loom is slightly different (plug between looms is different) re-arranging an ED manifold loom would be easier, then there is the problem of getting the runners to switch lengths, and some fiddling with accelerator and cruise cables
_________________ Because i can. |
falconea |
Just do a search, this has been covered so many times. All the info is on the forum if you look.
_________________ Drive safe, arrive alive
opto |
Ive done it
_________________ I post here cos the russian tank driver doesn't |
Users browsing this forum: No registered users and 74 guests |
