idle problem ea mpfi
 Post subject: idle problem ea mpfi
Posted: Thu Jan 05, 2006 4:12 pm
Ride: AU XR8
hi guys
im having problems with my ea mpfi.
when i pull up at traffic lights the idle will rise to about 1000 and drop to about 700rpm like its hunting for idle the isc has been blocked off for a while .it will hunt for about a minute then it will idle ok untill you stop at the next set of lights
when it does it i can turn the engine off and start it up straight away and its fine for about 10 mins..i think it might be the tps but when i looked at the tps it looks like new..
ive only had the car for about 4 months so i dont know when the tps was last replaced..
i will replace the tps . im just after others opinions as im sure its a common prob
any ideas what else it might be???
Posted: Thu Jan 05, 2006 5:52 pm
Ride: 2000 Au wagon
under normal circumstances the tps doesn't need replaceing,could be any thing from spark plugs to distributor,how old are your
1 plugs
2 leads
3 distributor and rotor button
4 injectors
how long since it had a tune,i don't think you can actually tune a injected vehicle.
process of elimination unfortunately..
Posted: Sat Jan 07, 2006 9:07 pm
Ride: AU XR8
hi
took the car for a drive today . and i noticed that with the air con on it idles fine ....
but when i turn the air con off the idle starts to go up and down again..
its not plugs,leads ect
so any ideas?????
It is currently Tue Jul 08, 2025 2:22 am All times are UTC + 11 hours
