Mike_EA |
Hey guys, i was just wondering what car i could rip a 3.45:1 diff out of ? I think getting one from work (Wreckers) would be cheaper then getting a new one yeah ?
cheers |
Southy |
EL FAIRMONT GHIA or FAIRLANE GHIA should have one. also herd a few EDs had them
dsheps83 |
El xr6 has them not the El fairmont ghia as i have the el ghia i only have a 3.23 LSD
fordzatmyplace |
Normal fairlane Ghia's didn't get em. Only the sportsmans did. But yeah
EF/EL XR6 EFII/EL Fairmont Ghia NF/NL Sportsman's some ED's can't remeber which, probably XR6/XR8's
_________________ ^^^ What He Said
downingj |
{USERNAME} wrote: Normal fairlane Ghia's didn't get em. Only the sportsmans did. But yeah
EF/EL XR6 EFII/EL Fairmont Ghia NF/NL Sportsman's some ED's can't remeber which, probably XR6/XR8's Nah, EF/EL Monty Ghias got the 3.23. |
fordzatmyplace |
are you sure? why did uglybobs EF Ghia have a 3.45 then? same with EFFalcons's EF2 Ghia:
http://www.fordmods.com/forums/viewtopi ... 61&start=0
Mike_EA |
Thanks for the replys. Just to clarify it's going into an EA. And another thing, are wagon and sedan exhausts "compatible" ?
- mike |
downingj |
{USERNAME} wrote: are you sure? why did uglybobs EF Ghia have a 3.45 then? same with EFFalcons's EF2 Ghia:
http://www.fordmods.com/forums/viewtopi ... 61&start=0 Now I don't know??? I always thought that they had a 3.23. Oh well, she's all good ![]() |
fordzatmyplace |
{USERNAME} wrote: Thanks for the replys. Just to clarify it's going into an EA. And another thing, are wagon and sedan exhausts "compatible" ?
- mike wagon exhaust are longer becuase of extra wheelbase so will not fit into sedan! unless you have it cut and welded ![]()
TimXR6 |
EF XR6 has 3.45
kezz |
you can also grab a 3.45 off an NC fairlane, as that is where i got my 3.45 lsd. my car is an ED
smoke_ |
did any el xr8's come with 3.45:1 diffs?
ebxmple |
ed xr6s have 3:45 lsd and if using complete diff housing they have extra upper arm mounting holes to take away vibration after lowering. If u are fitting diff assy into ea then u will have to either space lower arm bushes with washers or replace the 2 rear lower arm bushes with ed ones as they are wider. Just did this to a mates eb1 and had no dramas.
arm79 |
{USERNAME} wrote: El xr6 has them not the El fairmont ghia as i have the el ghia i only have a 3.23 LSD
We'll you've been dudded then mate. I've had / seen plenty of EL Ghia's and they are all 3.45's. |
dsheps83 |
{USERNAME} wrote: {USERNAME} wrote: El xr6 has them not the El fairmont ghia as i have the el ghia i only have a 3.23 LSD We'll you've been dudded then mate. I've had / seen plenty of EL Ghia's and they are all 3.45's. well may explain why the diff looked newsih, but the cones seem to slip heaps compared to my step dads Car (EB ghia) his is really tight. i noticed the diff looked nee when i was looking at the car to buy and the dude reckoined the owners changed it for towing ?????????? but the 3.45 would have been better towing |
Users browsing this forum: No registered users and 43 guests |
