kermey |
hey guys, my car wasn't charging the battery the other week so i got another alternator and still have the same problem. any1 know what could be the problem and how to find and solve the problem?
thanks in advance Kermey! |
Disco Frank |
regulator...
is the only other thing not sure if teh ea's had a internal regulator ( part of the alt ) or external
_________________ RIP SCOTT |
kermey |
if it is this it would have to be external as i have replaced the allternator right? so where is the regulator?
MARK.TANIA |
have a look at posative wire that goes to the allternator it might be brokern or power wires might have a bad conection
madmax |
EA has a internal regulator. that is the black box on the back of the alternator. Was this changed over with the alternator? or transfered from old one?
Slick |
most probably a dead battery.
Leroy |
did you test the battery?
kermey |
looks like i had made a bit of a d**k of myself, looks like i wasn't reving the car hard enough for it to start charging! so is that little box with the 1 wire the regulator??
thanks for your help guys! ![]() |
Slick |
{USERNAME} wrote: looks like i had made a bit of a d**k of myself, looks like i wasn't reving the car hard enough for it to start charging! so is that little box with the 1 wire the regulator??
thanks for your help guys! ![]() it'll start charging around 50kmh no matter the rev it is. go for a long drive, at least 1 hr or depending on how drained it is. alot of stop & go, short drives can drain your battery, it'll still charge but not to its full capacity.
smoke_ |
it should charge at idle unless the battery is not fully charged or it's stuffed.
Disco Frank |
{USERNAME} wrote: it should charge at idle unless the battery is not fully charged or it's stuffed.
whs!! 13.4v at idle!! unless u have a V8 with underdrive pulleys
kermey |
slick is right 50Kmh volt meter reads 14 volts! thanks!
Big Kev |
{USERNAME} wrote: slick is right 50Kmh volt meter reads 14 volts! thanks!
at what revs ... just curious
Slick |
{USERNAME} wrote: {USERNAME} wrote: slick is right 50Kmh volt meter reads 14 volts! thanks! at what revs ... just curious
kermey |
{USERNAME} wrote: {USERNAME} wrote: slick is right 50Kmh volt meter reads 14 volts! thanks! at what revs ... just curious not too sure, havnt really payed too much attention to the revs! |
