High beam headlight issue
Page 1 of 1 [ 5 posts ]
 Post subject: High beam headlight issue
Posted: Thu Dec 30, 2004 3:15 am
Ride: BA2 XR6T
jumped back into my ED the other day, to find that there is (most of the time) no high beam.
the relay still clicks when you hit the switch, and the lights sometimes work, but generally not.
im thinking probably the fusable links, but any other ideas ?
thanks guys.
BOOSTED
Posted: Thu Dec 30, 2004 12:04 pm
Ride: EF Gli Ghia, XP Fairmont
either replay is stuffed or not earthing properly! If it works sometimes then that would suggest the rest of the wiring is ok.
Owning 1 of 67612 EF GLi Sedans made
FACT: "Chuck Norris owns the greatest Poker Face of all-time. It helped him win the 1983 World Series of Poker despite him holding just a Joker, a Get out of Jail Free Monopoly card, a 2 of clubs, 7 of spades and a green #4 card from the game Uno."
 Post subject: headlights
Posted: Thu Dec 30, 2004 9:54 pm
relays can sometimes click but are still no good throw a new one at it and go from there
Cheers Lynchman
 Post subject: Re: High beam headlight issue
Posted: Fri Dec 31, 2004 2:52 pm
Ride: VZ SV8
thanks guys.
i agree with happy it cant sometimes work and sometimes not unless there is a problem with earthing.. maybe you have a wire which is rubing on metal and thats why they only work sometimes.
Check your wiring thats where i would start, if that doesnt work check your relay and if they are fine get some globes but i am 99% sure its not glodes
cheers
Mark
 Post subject: Re: headlights
Posted: Fri Dec 31, 2004 3:30 pm
Ride: 2004 BA Falcon MkII
I bought and wired up a brand new Narva 40 amp relay in the dragster a couple of weeks ago. It only works intermitently. It clicks in every time, but doesn't always make a connection. I pulled it out and bunged in an old Ford relay and it is working perfectly.
So go figure.
Kel.
BHR
A/MD 1272
240 inch Dragster
466 Big Block Ford
650hp
8.40 @ 156mph (251kph)
It is currently Sat May 17, 2025 4:41 am All times are UTC + 11 hours
