TimXR6 |
Afternoon all
Wouldnt mind fitting an oil cooler/filter relocation kit to my ef xr6. Are there any kits available? or is it a put it together yourself jobby. cheers Tim |
tickford_6 |
basicly you just buy the parts and put it together.
the take off and remote filter bosses are easy to get as ford used the same filter for 6s and 8s the coller itself is much a case of take your pick. stacked plate cooler will cool better but have a higher pressure drop tube and fine will have less pressure drop but will cool slightly less for a given size http://www.vpw.com.au/product.asp?CatID ... dID=126337 that a link to a remote filter with cooler universal fitment. you just have to let them know what filter the car uses |
dsheps83 |
any advantages in this besides the oil being cooler
TimXR6 |
not really. but there doesnt need to be.
keeping oil cool is enough for me. Same function as a radiator, IC or trans cooler. thanks for the reply tickford 6. Petty they dont provide a little more info on that kit. cheers. Tim |
tickford_6 |
you basicly order the right size cooler the take off plates and the hose.
the take off plates for a windsor or clevo are the one you wants. a 6 or 8 pass tube and fine cooler and a few meter of hose and the right fittings. if you drop into a local performance shop they'll help with hose and fitting of the right size |
Users browsing this forum: No registered users and 39 guests |
