Increasing capacity of intake manifold
Page 1 of 1 [ 8 posts ]
 Post subject: Increasing capacity of intake manifold
Posted: Tue Oct 24, 2006 12:48 pm
Ride: 97 EL XR6
Power: 162 rwkw
was looking at the cast intake manifold off an el, it looked like there was a fair amount of excess steel sitting in the chamber (a main cross member plus a couple of other areas), im not sure if its there to maintain some sort of air flow or not, but if the manifold was to be cut and most of this steel removed from inside it, leaving one big hollow chamber, this would increase the capacity for air within it, would this be worthwhile or not? anyone tried it?
07 BF MKII XR6T
310rwkw @ 13psi - Tuned By CMS
Posted: Tue Oct 24, 2006 1:28 pm
Ride: EA2 'Mont
why not just put a box plenum on top like others have?
much less stuffing around
Posted: Tue Oct 24, 2006 1:43 pm
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
That 'excess steel' is to create the dual runner lengths the BBM has.
It switches from long runners (for good low down torque) to short runners (for top end power).
BF MKII F6 Tornado - 237rwkw
Posted: Tue Oct 24, 2006 2:14 pm
Ride: No Fords current
On top? Like remove the top half of the BBM and fit an aftermaket one? I would of thought in NA application the duel runner system on the BBM would be better than a plenum chamber set up.
Posted: Tue Oct 24, 2006 3:55 pm
Ride: Toyota Supra RZ
the only time i've seen the plenum idea done was with a forced induction.. ie pyroay has had a plenum top half made up and rmyers has taken out the BBM butterflies and opened up the chamber completely but again this isnt NA..
Posted: Tue Oct 24, 2006 6:07 pm
What Rymers has done, didn't Ford do the similar thing on the XR6T's? A BBM with no butterflies.
Posted: Wed Oct 25, 2006 12:59 am
Ride: Falcon EB-s
svo_xr6 also removed the top of the plenum and put on twin throttle bodies?
Posted: Sat Jan 27, 2007 2:53 pm
Ride: E-Hybrid Falcon
you might be hard pressed finding steel in the cast aluminium manifold.. unless your going to decrease the size of the steel in the butterflies.... or the gasket...
crow cam,cai,exaust,bbm,190 reg & el injectors,xr6 interior,guages,white cluster,pioneer/mtx stereo,big boot install w.i.p, 17"rims,koni/pedders shocks&springs with nolathane re-bush,ssv kit,stainless inserts,clear lights,t5 & short shifter,chardonay/pearl paint
Users browsing this forum: Google Adsense [Bot] and 0 guests
cron
It is currently Mon May 19, 2025 3:19 pm All times are UTC + 11 hours
