kezz |
ok first i thought it was the power steering belt, so i tightened that but it didnt do jack.
when i first start up the car it screeches, so i give it a few revs and it shuts up. i put the car in drive and it starts all over again, and subsequently gets worse when i take off untill maybe 2500/3000 rpm. im embarrassed to stop my car at the lights cos of the noise ![]() anyone know what it is, im thhinking a belt but what belt? ![]() thanks Kezz
eed-250 |
maybe the belts are dry?
rub them with the special soap u can buy and see what happens? |
kezz |
{USERNAME} wrote: maybe the belts are dry?
rub them with the special soap u can buy and see what happens? special soap? can you give me some more info on this mate?
kempster1 |
Could be any of the belts that are slipping.
Does it have aircon?? That would be the forst one to check, it needs to be tighter that a alternator belt or power steering belt. Also check that your belts are not badly worn to the point where they are bottoming in the pulleys, you will never get them to stop making noise if they are that worn
_________________ Peter Kempster |
kezz |
yeh its got aircon,the aircon belt seems to have abit more free play then i would have liked. maybe its that.
Froudey |
Quote: rub them with the special soap u can buy
what Dove?? ![]()
gutza |
You may have already tried this.
Not sure if ED's the same belt setup, but I had a similar problem with the EA. I had a sqeaking and a rubbing sound which went away with a few revs and turning the stereo up. The bearing on the PS idler pulley ( front of head ) was stuffed. Loosen the PS belt , pop it off the idler pulley and see how smooth the pulley turns. A new bearing is about $5 or a complete bearing / pulley about $30. |
kezz |
bearing/pulley is that the metal thing that holds all the pulleys?
Leroy |
yes. its the adjuster that the belt runs around.
kezz |
ok had another look ands when the car fires up it doesnt have much voltage at all. this has something to do with the alternator i suppose? how do i check and make sure the alternator belt is the prob?
thanks
kezz |
no one can give me an idea? come on guys this is getting embarrassing...
qwerty68 |
on my eb the air con belt did it
_________________ Lukey Extractors 2.5" Exhaust 3.23:1 Diff 17" BA XR8 Alloys |
kezz |
almost 100 % its alternator related, i got almost 0 voltage on the dash meter thingy
menaceEF |
That usualy mean s the alternator belt is slipping. Is it too loose? Another suggestion is to get a can of WD lube or silicon spray and srap each belt till the sound goes away. and if it doesnt spray each bearing like the idlers and p/s pulley bearings. there is away to check your alternators chargeing rate, but i am not entirely sure how to do it. just search yahoo. Hope this helps you a little
Cheers |
Xflow |
Age: 37 Posts: 721 Joined: 31st Dec 2005 Ride: EF V8 Futura, 180sx Location: Brisbane, Burpengary |
Quote: That usualy mean s the alternator belt is slipping. Is it too loose? Another suggestion is to get a can of WD lube or silicon spray and srap each belt till the sound goes away. and if it doesnt spray each bearing like the idlers and p/s pulley bearings. there is away to check your alternators chargeing rate, but i am not entirely sure how to do it. just search yahoo. Hope this helps you a little
Cheers im dont know 100% but if you got a multi meter and put the negative on a earth the put the positive on the back and it should tell you how many volts you have if it say 0 volts yer will ya alternater stuffed or slipping hell of a lot give that a go see how ya go
_________________ Ford EF Futura Black
