cabridge |
on my ef 2 Gli, the diff has been pissing out ALOT of oil from the top and the bolt where you change the oil, all bolts are tight, NEVER DO ANY BURNOUTS
msman |
the bolt to fill up the diff has a soft washer aluminium i think just go and replace that takes abt 2 mins if that, rest i think the gasket of the cover may have broken or burn't out or somthin, i don know, pretty easy t replace thou, get the hand brake cable out of the way, undo the swaybar thingy and twist it over the diff undo all the bolts arnd the cover and use a flat head screwdriver to slowly remove it, sand it back and replace with new gasket.
_________________ why do u write in here. |
Users browsing this forum: No registered users and 32 guests |
