airbag
Page 1 of 1 [ 8 posts ]
 Post subject: airbag
Posted: Wed Mar 29, 2006 6:04 pm
g'day my air bag light is on,ive got and ef xr6....i havnt smaked it or anything,apparently i can reset it?but i dun know how?the fuse is ok....pls help
Posted: Wed Mar 29, 2006 6:09 pm
Ride: BA Falcon Suzy Across
Power: 178 rwkw
I really wouldn't have a clue but if you can reset it, maybe it can be done by resetting your ecu by unplugging the battery for a few minutes but this is just a wild guess ok.
178.3 rwkw
15.1@96 mph
Now with 3.9 shrooms
Posted: Wed Mar 29, 2006 6:33 pm
Ride: BA GT
i "think" ford have to do it mate!
Posted: Wed Mar 29, 2006 6:58 pm
Ride: EF GLi 5-spd & BA 'mont
could be a malfunction with the airbag module, or the airbag itself. Most workshop manuals (eg. Gregorties) usually have a section on DTC's. You just have to earth out the correct pin in the diagnostics connector. The airbag light will blink a few time, you then compare the no. of blinks with the manual. eg 3 blinks= internal module failure. Sometime you have to do it 2 or 3 times before the light will go out, but it can be done without emptying your wallet to Fraud.
Sig pic removed, refer to http://www.fordmods.com/forums/signatur ... 29751.html
Posted: Wed Mar 29, 2006 7:05 pm
Ride: AU 1 Tonner
there was a post on here about the airbag light i saved it to do mine and i cant remember where i saved it but i know its on here do a search
To be old and wise you first have to be young and stupid
Posted: Thu Mar 30, 2006 2:10 am
Gallery: 24 images
you can clear the codes by shortin 2 dianostics pins IIRC. if the light stays away all good, if it comes back will need to go thru diagnostics to find out what it is
 Post subject: thanks guys much appriciatd
Posted: Thu Mar 30, 2006 4:17 pm
how do i shortin da pins???
Posted: Thu Mar 30, 2006 6:01 pm
Have a read of this http://www.fordmods.com/phpBB2/documents.php?doc=3
It should be able to help you
It is currently Sat May 17, 2025 8:38 pm All times are UTC + 11 hours
