auspom |
Hi Guys
New to the Forum and hope to meet new freinds and share some experiences. About to purchase an EF Fairmont 1995, 1 Owner from new, 154,000ks with full log book history and owner has it maintained regardless, however on idle it seems to run a little rough as if its missing slightly but when you rev up its as smooth as silk, owner has stated that it could be the computer but he really did not know but carried on to say that it has been like this for the last 3yrs and is so insignificant that it did not bother him. Any guys got any idea what it could be taking into consideration it being a one owner with fairly low ks and well looked after. Thanks in advance. Tony (Auspom) |
Krytox |
I know, I know.... its a ford!
i think you'll find nearly everyone with a i6 has an erratic idle... I tend to think Manuals have it worse as theres less Dampening on the flywheel Some say theirs is better with: ISC clean Injector Clean New Fuel Filter 98Ron Fuel High Volume Regulator/Pump New quality Leads New Plugs Reset ECU New Cat New/Clean 02 sensor Performance AIr Filter Larger Cold Air Intake New Coil Pack 'high pressure cleaning' I however... bah.. either way...it still does it! PS: Welcome!
_________________ Carefree, we may not be number one, but we're up there. Last edited by Krytox on Sat Apr 01, 2006 10:40 pm, edited 1 time in total. |
noisy |
My EF FAirmont does the same has for 100,000kms you name it ive either fixed it, cleaned it or checked it, since it hardly gets driven anymore it doesnt bother me now
Pulco |
id be checkin the inlet manifold gasket, happened to mine, got a vacuum leak, just spray carby cleaner or soemthin of the like around it and if theres a hole in the gasket the revs will rise then fall
Users browsing this forum: No registered users and 41 guests |
