speed limiters
Page 1 of 4 [ 46 posts ] Go to page 1, 2, 3, 4  Next
 Post subject: speed limiters
Posted: Thu Mar 23, 2006 9:41 pm
Ride: au xr6 3
what has to be done to remove the speed limiters on el fairmonts?
GO THE MIGHTY FORD
Posted: Thu Mar 23, 2006 9:42 pm
Gallery: 24 images
a) trans cooler
b) new tailshaft
c) xr ecu or piggy back chip
Posted: Thu Mar 23, 2006 9:44 pm
Ride: au xr6 3
whats the tail shaft got to do with it?
GO THE MIGHTY FORD
Posted: Thu Mar 23, 2006 9:48 pm
Ride: au xr6 3
and wont it run like a dog on the xr6 ecu ?
GO THE MIGHTY FORD
Posted: Thu Mar 23, 2006 9:50 pm
Ride: BA Falcon
the standard tailshaft isnt designed to spin faster than 180kmh. the xr one is alloy and can cope with it.
Posted: Thu Mar 23, 2006 10:17 pm
Ride: 5 Star Boxcar
yeh stuff being in the car when the tailshaft snaps :shock:
why you wanna get rid of the limiter? so you can do 180 + up the m4 lol?
Kezz's 5sp Box Car ---> RPD enhanced with a bunch of other stuff
Posted: Thu Mar 23, 2006 11:20 pm
Ride: EL Monty
Why would you bother removing the limiter
Posted: Thu Mar 23, 2006 11:35 pm
Ride: 2003 BA XT
(RUMOUR ALERT)
I got told by a bloke at work that by reversing two wires somewhere down near the fuse area it lifted the limiter.
Can anyone confirn if this is a load of "i tell lies" or is it true?
Posted: Thu Mar 23, 2006 11:53 pm
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
(RUMOUR ALERT)
I'd put money on it being a load of "i tell lies".
The speed limiter is programmed into the EEC.
BF MKII F6 Tornado - 237rwkw
 Post subject: Re: speed limiters
Posted: Fri Mar 24, 2006 12:51 pm
dont mean to rain on your parade, but where are ya gunner use over 180kph, i couldnt see ya using on a the 1/4 mile in a stokie el, just curious???
Posted: Fri Mar 24, 2006 2:12 pm
(RUMOUR ALERT)
Im going with a load of lies..
The only way that is remotely close to what he is saying is to remove the VSS Out wire from the instrument cluster.. speedo gear goes into cluster, and then normally to pin 3 (EB/D/L) on the ECU.. disconnect that and ECU thinks you are doing 0.
Not to mention that I agree with the rest of the people on not doing those speeds...I tailshaft goes snap at 180, you'd be wishing your limiter was set to 60.
Atleast put on tailshaft loops.
;++JustForDimSim++;
Posted: Fri Mar 24, 2006 7:35 pm
Ride: AUII Fairmont
They are limited because of the tailshaft
My car has no limiter - or so I'm told, but geez I've never tried to get up to 180! Seriously why would you?
Posted: Fri Mar 24, 2006 7:54 pm
Ride: Soarer 2.5GT-T
I did 215 in mine once. Traffic is very scary at that speed.
Posted: Fri Mar 24, 2006 8:04 pm
Ride: BA GT
TRAFIC! i dont think you would want to be doing thoes sorts of speeds in "traffic"
Ride: Ford FPV FG F6 310
Power: 149 rwkw
i got an xr6 ecu but i don't plan to hit the limiter anytime soon, at least till the alloy tailshaft gets put in there
Users browsing this forum: No registered users and 56 guests
It is currently Sat May 17, 2025 4:16 pm All times are UTC + 11 hours
