Window slowing down help needed
 Post subject: Window slowing down help needed
Posted: Thu Apr 13, 2006 10:01 pm
hi guys got a ef fairmont 94 sedan, every time i seem to bring my window electronically for half the way goin up it slows down and the rest of the way it goes at normal speed ne help would b much appreciated i dont want it to fuk up like my back one did that doesnt even work now
Posted: Thu Apr 13, 2006 10:10 pm
Ride: Isuzu MU-X ,2018 Kia Cerato
get some silicone spray or graphite powder.
'96 DF II LTD 6cy
'15 Isuzu MUX LST
Posted: Thu Apr 13, 2006 10:19 pm
Gallery: 13 images
Ride: BA MKII XR8
Sorry to hi jack, but I have the same problem, but in reverse.
Mines will go all the way down without issues, but sometimes when I power it back up, it seems to shift out of place and get stuck. I have to tap down on the power window button, then tap up. Then down, then up and she usually goes up. It's like it's out of allignment.
My mate had the same problem in his Futura. He said he just sprayed the rails with some sort of lubricant (which was only a temporary fix)...
Posted: Thu Apr 13, 2006 10:20 pm
Ride: AU Futura
I use Nulon Ezi- Glide silicone spray works great.
http://www.nulon.com.au/products.php?productId=ezi330
Posted: Thu Apr 13, 2006 10:21 pm
Ride: AU XR8
for a quick fix spray armourall into the window tracks..
it worked ok for me...
Posted: Fri Apr 14, 2006 1:20 pm
Ride: EL Fairmont
Get some lube lol works wonders :P
Posted: Fri Apr 14, 2006 8:51 pm
Ride: EL XR6
If you want to do it properly you have to get the regulator replaced. But like the guys said just lube it up and it should work ok so long as you keep the lube up to it
5spd Heritage Green EL XR6. Wheels by ROH. Stereo by Clarion. Exhaust by Pacemaker & Lukey. Suspension by Whiteline, Durashock and K-Mac.
Posted: Fri Apr 14, 2006 8:52 pm
Ride: EL XR6
my bad double post
Posted: Fri Apr 14, 2006 8:57 pm
Ride: 5 Star Boxcar
i think the lube will eventually have the opposite effect. the silicon spray will attract s**t to stick on it, making it harder for the window to travel up
Kezz's 5sp Box Car ---> RPD enhanced with a bunch of other stuff
Posted: Fri Apr 14, 2006 9:53 pm
I've never had a power window s**t its self in my car thay always go up nice just spray a little bit of silicon spray every month or so. it dosent seem to attract s**t.
'96 DF II LTD 6cy
'15 Isuzu MUX LST
Posted: Fri Apr 14, 2006 10:03 pm
Ride: 5 Star Boxcar
well after replacing my one of my window regulators that i sprayed with silicon spary i noticed a heap of stuff stuck to it compared to the other regulators that i never sprayed.
Posted: Sat Apr 15, 2006 8:54 am
Ride: Ford FPV FG F6 310
Power: 149 rwkw
i just adjust mine, works every time.
there are 2 bolts holding the window to the rail, just play around with moving it around.
it may take some time, it took me 1/2hr to get mine right the first time.
oh and once you've done that, the graphite down the rails won't hurt either.
Posted: Sat Apr 15, 2006 11:10 am
Ride: BF XR6, BF XT Wagon
Power: 197 rwkw
CRC silicone spray works fantastic.
Mine used to never go back up without my hand helping it up.
Now after silicone spray its like brand new and now I can have window races.
Posted: Sat Apr 15, 2006 5:09 pm
Ride: el faimont, dual fuel
go to ford spares this is a common problem, ford came up with a fix in the form of a liquid lubricant, only needs to be applied once every service.
should be about $30, last time i checked, for a bottle that does 300 windows approx.
assuming that the window is all lined up etc, and just jamming because of friction.
why do u write in here.
Posted: Tue Apr 18, 2006 6:02 pm
Ride: AU Futura
Never attracted and dirt or any thing else since i have been using it!
It is currently Sun May 18, 2025 9:34 pm All times are UTC + 11 hours
