ba CAI
Page 1 of 1 [ 13 posts ]
 Post subject: ba CAI
Posted: Sun Apr 23, 2006 10:26 pm
Ride: ba falcon
im looking to improve my air intake on my ba. i have seen this on ebay,
just slightly larger than the current snorkel, should i buy this? is there anything better i can get and any other improvments i can make? http://cgi.ebay.com.au/FORD-BA-Large-Co ... dZViewItem
Posted: Sun Apr 23, 2006 10:29 pm
Ride: BA XT, BA XR6T, ED Ghia 5.0
yeah you can get that. Also worth getting is the BA V8 intake which goes underneath the headlight to the airbox. You'll need to cut a hole in the bottom of your airbox but you'll end up with two intakes which helps.
What's the difference between a Holden and a sheep? It's less embarrasing getting out of the back of a sheep..
Posted: Sun Apr 23, 2006 10:33 pm
Ride: Shockwave BA XR6
Power: 152 rwkw
get the typhoon lower airbox and snorkels like i did
youll spend about $170 to buy it
look for bayford spare parts on ebay (i work for them and thats how i found mine ). you will love it.
Posted: Mon Apr 24, 2006 9:07 pm
Ride: ba falcon
cant see that bayford on ebay.
is this the v8 intake u were talking about fnp?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... Track=true
how is the typhoon setup different from the xr8/ and snorkel combo? brett?
Posted: Mon Apr 24, 2006 10:04 pm
Ride: AUII XR8 Ute
The BA XR8 has the pod style airbox instead of the more common box shape.
Narooma Blue, Manual, 19" rims, Phenolic Spacer, T-Series Brakes, 3.9 Diff Gears, Custom Fabricated CAI, Pacemaker Headers.
Posted: Mon Apr 24, 2006 10:13 pm
Ride: BA Fairlane Ghia
So where does the rubbery thing, in the post above, go?? it sits poking out the bottom of the airbox?? what is below the airbox?? a space/hole etc?
Posted: Tue Apr 25, 2006 10:26 am
Ride: No Fords current
I think it pokes out the front of the air box to behind the passenger side headlight to suck air through any gaps in the headlight/front bartype thing...
Posted: Tue Apr 25, 2006 3:33 pm
Gallery: 23 images
Ride: XR6 Turbo
what CAI meen, current air intake?
SS Inductions CAI, K&N Filters, M-spec FMC, Turbosmart BOV, 8psi capa tune, X-force cat.
Mods going on: Nizpro springs, bosch 040 pump + Walbro gss341, 600cc injectors, PWR transcooler, 20% Underdrives, 15psi Actuator, Kingspring SSL's, 15psi tune.....More coming
Posted: Tue Apr 25, 2006 3:45 pm
Cold Air Intake.
Posted: Tue Apr 25, 2006 4:12 pm
i did the same, i believe it works well.....not too expensive either compared to the SS inductions intake system
Posted: Tue Apr 25, 2006 5:27 pm
Gallery: 23 images
Ride: XR6 Turbo
AHHH thanks
 Post subject: bayford parts on ebay
Posted: Thu Apr 27, 2006 8:19 pm
for those looking for bayford parts on ebay
do an advanced search and then search by seller and the seller id is bayford_parts
Posted: Thu Apr 27, 2006 9:47 pm
Ride: ba falcon
ah i see the typhoon setup. it doesnt seem any different than buying the 2 items i posted off ebay so i think ill go with the cheaper option.
Users browsing this forum: No registered users and 41 guests
It is currently Tue May 20, 2025 2:06 pm All times are UTC + 11 hours
