accelerator cable
Page 1 of 1 [ 9 posts ]
 Post subject: accelerator cable
Posted: Thu May 18, 2006 7:57 pm
Ride: BOXCAR
I have a perfectly healty 3.9 Auto that will refuse to rev past 4000 rpm when in D. It will only go past that if i hold it in 1 or somthing. To cut a long story short i had my dad hold his foot flat to the floor (with engine off :P ) so i could check if it was getting full throttle. When he did this, I noted that the throttle was only 3/4 of the way open. Is this a common problem or are they all like that? What is required to fix it? a new cable?
car has the "log" style manifold
^^^ What He Said
Posted: Thu May 18, 2006 8:18 pm
it's pretty common for the outer of the cable to break up, they dont cost much and are easy to replace
Posted: Thu May 18, 2006 8:26 pm
Ride: EA
buy a new cable ages ago mine was never getting full throttle n wen i fixed it , it got faster
Ford Falcon EA Naturally Aspirated 4.0L i6
13.797 @ 157.16km/h (Limiter Bounce)
Posted: Thu May 18, 2006 9:15 pm
Ride: BOXCAR
can you still buy EA-ED cables from ford? There quite old now. What about XH cables?
Posted: Thu May 18, 2006 9:16 pm
sure can
Posted: Thu May 18, 2006 9:18 pm
Ride: BOXCAR
cheers, will it give me full throttle again? or did they all get throttle stops in them or somthing?
Posted: Thu May 18, 2006 9:30 pm
it will give you full throttle again.
Posted: Thu May 18, 2006 11:02 pm
I replaced mine and there about $55. You will notice wide open throttle again plus heaps better throttle response when driving around town..
Posted: Thu May 18, 2006 11:21 pm
Ride: 5 Star Boxcar
the throttle plate thingy was removed from my car and "bastardised" to make it reach full throttle. worked a charm
Kezz's 5sp Box Car ---> RPD enhanced with a bunch of other stuff
It is currently Sun May 18, 2025 12:58 pm All times are UTC + 11 hours
