4.0ltr head work..
Page 1 of 1 [ 9 posts ]
 Post subject: 4.0ltr head work..
Posted: Wed Jun 21, 2006 7:13 pm
Ride: falcon eb
hey peeps just been looking into gwtting some head work done, camaccross thisand may be considering it..
just after som feedback on what u guys think..
The Stage 3 utilises a large valve for increased air flow in the higher valve lift. We can maintain the same port speed as in the stage 2. The air flow numbers are greater by 10-15 CFM on the 300-500 thou of valve lift. These heads will handle 550 net valve lift. SuperFlow flowbench report supplied.
PART NUMBER - SPH3LV
PRICE - $1386 V8, $975, 6 CYL, $693 4 CYL* Ask About CNC porting
FEATURES
New O.E. valves.
High flowing valve seats.
New valve locks.
Radius leading edge on exhaust valve.
Threads re-tapped.
Exhaust valves are backcut.
Head gasket faces re-machined.
Intake valves are backcut.
Full set of K Line guides.
Blending the valve seat to the bowl.
Bowl machine work.
Large Valves.
New 4140 valve retainers.
New valve stem seals.
Valve tips equalized.
Spring pressure checked.
Combustion chambers relieved.
All spring heights are re-corrected.
New set of chrome silicon valve springs.
Valve heights equalized.
Hot tanked.
Sand Blasted.
Vacuum tested.
Clean, assemble and pass quality testing.
OPTIONAL EXTRAS
Top gasket set - V8:$210, 6 Cyl:$187.
One piece stainless valves - V8:$562, 6 Cyl:$462.
Roller Rockers - V8:$693, 6 Cyl:$660.
Standard rockers - V8:$150, 6 Cyl:$95.
LPG conversion kit - V8:$528, 6 Cyl:$447.
3Additional port work - V8:$750, 6 Cyl:$700.
Chrome taller rocker covers - V8:$105 6 Cyl:$95.
Will produce 265hp & 279 ft.lbs of torque at the flywheel
for $975 what u recon
cam is xtra $550
Posted: Wed Jun 21, 2006 7:44 pm
Gallery: 15 images
Power: 236 rwkw
Sounds like Kostecki Engine Centre
STREETBUILT RACING
Posted: Wed Jun 21, 2006 8:32 pm
it surely does.
for the money i'd go the CNC head they do
Posted: Wed Jun 21, 2006 8:54 pm
it surely does.
for the money i got the CNC head they do
For your money i would go the CNC head too!! I asked for a quote!
The cnc head is available in port 2 version and they are come complete, the price are $2800.00 for the street strip version and the full competition is $3200.00 this head has different valve sizes and will need a increase of compression please do not hesitate to call me in regards to your combination
Posted: Thu Jun 22, 2006 3:11 am
Ride: EF Falcon
whoa big money
EFBIGNIK 145.9 RWKW Falcon / 16.27 @ 86.72mph (Stock)
http://s60.photobucket.com/albums/h38/e ... urnout.flv
Posted: Thu Jun 22, 2006 3:39 am
Ride: falcon eb
sure is guys
heheh
yeh been looking into it all. good thing another site i help handel has discounts with em.
best thing is they do courses to ..and i live 2 mins down the road
Posted: Thu Jun 22, 2006 8:31 am
when i called them the cnc job was $1400
don't know where you got 3000 from
Posted: Thu Jun 22, 2006 7:44 pm
Ride: falcon eb
lol same price they told me tickford_6
wonder ing what ecu would i need to run with it aswell would the std bottom end hold up alright ??
nother thing is injecters????
Posted: Thu Jun 22, 2006 7:48 pm
that comes down the cam you use.
Users browsing this forum: No registered users and 42 guests
It is currently Sun May 18, 2025 9:24 am All times are UTC + 11 hours
