JMM
Page 1 of 5 [ 67 posts ] Go to page 1, 2, 3, 4, 5  Next
 Post subject: JMM
Posted: Fri Nov 05, 2004 4:28 pm
Gallery: 13 images
How much would they usually charge for some sparkies installed and a dyno run?
cheers
Succesful trades with bentles_eb, Pane, chunkz, xr8_dismantler, OBS35N, mrnasty, Steady ED, voxace, Mash85, ovo616, ef biff, lukey, dazza2924, Seannyb, gunit18, jkk, Tocchi,
Posted: Fri Nov 05, 2004 4:41 pm
Ride: NL V8 Fairlane
Spark plugs? They use autolites iirc and they aren't cheap, easily $200 for 6 I think.. The dyno run can't be more than $100 so $300 max?
Posted: Fri Nov 05, 2004 4:42 pm
Gallery: 29 images
Ride: VU SS
$60 for a dyno run I think, and $45 for the plugs IIRC...
EF Fairmont now Sold!
Guides: {DESCRIPTION}|{DESCRIPTION} |{DESCRIPTION}
Posted: Fri Nov 05, 2004 4:44 pm
Ride: EF Fairmont 5.0
If you can't change your own spark plugs, I don't think you should be driving a car.
And I personally wouldn't use JMM's dyno, as it's been known to read up to 30% higher than real dyno's.
Posted: Fri Nov 05, 2004 4:46 pm
Ride: EL Fairmont
autolite plugs arent worth more than $18, some FF people have aquired them for arround this much. Instalation is nothing that cant be done in 2min at home.
Soo many idiots. So few bullets
Posted: Fri Nov 05, 2004 4:47 pm
Ride: AUIII Futura
So just how accurate are "real" dyno's
"Every day above ground is a good day"
"Still drinking & driving, but not at the same time"
http://groups.msn.com/picturesofyourcar ... utura.msnw
Posted: Fri Nov 05, 2004 4:52 pm
Oops, I was referring to NGK Iridium prices. :oops: Autolites are meant to give you a few extra kw but I wouldn't believe it...
As others have said, if you can't change plugs on a I6 don't even think about getting a V8. 8)
Gallery: 13 images
sorry what i meant was how much will it cost me to get them,? i would be installing them myself, then a dyno run
cheers
Posted: Fri Nov 05, 2004 5:39 pm
Ride: FG II G6E TURBO
$60 plugs
$90 a run on the dyno, but id go elsewhere to get the dyno done mate, well thats just my opninion anyway
Posted: Fri Nov 05, 2004 5:44 pm
Ride: BF Typhoon
Anybody had good experience with these plugs?
Everyone ive spoken to and know who has used them swears they are sh|t to be honest, not that id ever think of getting some.. :lol:
BF Typhoon, Dejavu - 6sp Auto, Leather, Sunroof, 19"s, Electric Pedals, Tint, FPV Sports Wheel, FPV Mats.
Posted: Fri Nov 05, 2004 5:52 pm
Gallery: 13 images
what are some good plugs to get? maybe even a good set of leads that anyone can recommend i have already done the oil and filter, used some nice mobil semi synth, brought the oil pressure back up a bit too, but the engine has only done 170,000 so far
cheers guys
Posted: Fri Nov 05, 2004 5:54 pm
Gallery: 13 images
cheers guys
i've heard woolies supermarket sell home brand spark plugs that give up to 20 more RWKW, j/k
Accel make some good spark plugs and i go for Eagle leads.
4 cylinders are like chinese food, few minutes after you have them you just want more!
Posted: Fri Nov 05, 2004 6:11 pm
Ride: V8 T5 Fairmont & BA XR6T
Im running auto lites and they are great. do some research and you will probably find them cheaper than JMM but they are only $45 from them anyway. They do provide a better burn as they sit further into the combustion chamber, so no arguements can be made as to them being worse than other plugs, just make sure you gap them to 0.9mm wher you get them.
Dima, Mitch & Jay's RPD
Posted: Fri Nov 05, 2004 6:17 pm
Gallery: 37 images
Ride: V8 EF Futura
If you're chasing horsepower, plugs arent the way to do it. The other way around - select the right plug for your mods to get the most out of the engine. Any decent brand with the correct gap and heat rating should be fine.
Having said that, an independent (i.e. not on the dyno of someone who has a financial gain from promoting said product) dyno test would be interesting
Posted: Fri Nov 05, 2004 6:29 pm
Gallery: 13 images
is that how it is? im beginning to understand now, lol
cheers guys
Users browsing this forum: Google Adsense [Bot] and 2 guests
It is currently Sat May 17, 2025 3:00 am All times are UTC + 11 hours
