kezz |
all fixed up now guys! it was the battery in the end. beyond me why it died like that but i guess it happens. thanks to everyone for their help and suggestions!
_________________ Kezz's 5sp Box Car ---> RPD enhanced with a bunch of other stuff Last edited by kezz on Tue Aug 08, 2006 11:03 am, edited 1 time in total. |
smiley235 |
check to see if you've knocked out any wires near the clutch cable, the batery light might be coming on for that reason. Also, check the batteries voltage with a voltmetre if you've got one.
_________________ 178.3 rwkw
madmax |
Sounds like the battery is nearly flat.
kezz |
{USERNAME} wrote: Sounds like the battery is nearly flat.
grrrrr i hope thats the cause of the prob cos its the easiest fix
fordzatmyplace |
{USERNAME} wrote: as the title suggests the car wont start
![]() ![]() if the starter relay clicks, then its definatly not a smartlock problem. Does the engine turn over? If not try bridging the starter (the car won't start but it will eliminate the starter as a possible cause)
_________________ ^^^ What He Said
TwinturboBMX |
I had a similar problem and it turned out to be a fuel pump in the end.
Like you could hear a click then you hear a pump type buzzing noise, but nthing happens.
_________________ 17" Tezza Steelies, King F**king lows, pedders sports ryders, 2.5" cat back exhaust, pacemaker extractors, T5 manual
kezz |
better not be the fuel pump. that sounds like a right royal prick of a job
TURBO_GHIA |
id try another battery ,and if its the fuel pump i can help ya fix it ,its not that hard
_________________ HMMMM BOOST !!!
TwinturboBMX |
As said kezz, check the battery first then check smartlock relay etc (mine had a dodgy one), then check fuel pump, if its the fuel pump make sure your not going fast and around a sharp bend.
Kinda scares the s**t out of you when it goes as you lose alot of steering capability and braking.
TURBO_GHIA |
have ya been playing with the stereo at all ?
kezz |
nar havent touched the stereo, the only thing ive been playing with is adjusting the clutch cable. il try a new battery tomorrow. thanks for the offer of help if its the fuel pump Jarrod mate! il certainly let you know if it is that.
Users browsing this forum: Google [Bot] and 53 guests |
