BCM
 Post subject: BCM
Posted: Tue Jul 11, 2006 11:48 am
Ride: NC II Fairlane
Could someone tell me where the Body control module on a 92 fairlane is.
thanks
"Looking at cleavage is like looking at the sun. You don't stare at it. It's too risky. You get a sense of it and then you look away."
Now with el thermos fitted.
Posted: Tue Jul 11, 2006 11:56 am
Ride: 96 XH/97 EL
IIRC behind the dash above the hand brake handle - smartlock module will be next to it (where fitted).
Posted: Tue Jul 11, 2006 6:48 pm
Ride: BOXCAR
are you after the BCM or the Smartlock module?
The BCM is a bit tight to get at, look up under the dash for the green box and you'll see what i mean :o
The Smartlock module is above the handbrake
^^^ What He Said
Users browsing this forum: Facebook [Bot], Google [Bot], Google Adsense [Bot] and 31 guests
It is currently Wed May 21, 2025 8:13 am All times are UTC + 11 hours
