daggy082 |
Hey guys last nite i put in a new head unit in my EF2 and to do that i had to disconnect my negative terminal for longer then 1/2 hr and now its dropping down to 300rpm sometimes wen coming up to a corner. Would that be that the ECU is relearning itself?
KRUPTD |
Maybe it could be.Get your engine to operating temperature and then disconnect the isc plug and adjust your idle speed.Sounds like your idle speed is too low.Make sure you spray a little wd40 on the little idle screw.Remember when disconnectiong the isc the engine drops 200rpm so when adjusting your idle account for that.Hope that helps.
_________________ COMING SOON,XD WITH A TURBO...CLEVO STYLE |
daggy082 |
Thanks 4 the info. The thing is ive had the car 4 3 weeks now and the idle has been perfect but it was just after i disconnected the battery it has been doin this in the last day. ive Searched the forums and found many post saying that the only thing u get outta of reseting ya ecu is that its gonna make it run rough 4 a while.
KRUPTD |
Just see how you go,get your engine warm and adjust your idle then take it for a 10km drive and see how it goes after that.
MacGyver |
To adjust idle speed put car into diagnostic mode. Then adjust idle speed with a 0.75mm feeler between the idle speed stop and idle speed screw. This will allow the ISC full control once out of diagnostics.
_________________ If it doesn't fit, jam it. If that doesn't work use a hammer. - Engineers Motto |
daggy082 |
MacGyver im new to the world of computer controlled cars (previously had XF and 67 Xr falcon). So how do u put it in diagnosis mode? Thanks
martyel |
have you tried restting the ecu? i had the same when i replaced my head unit
martyel |
daggy082 |
Like i thought in my original post. It was the ecu re-learning itself. Went 4 a 300km drive and by half way it was idle fine.
Users browsing this forum: No registered users and 35 guests |
