Think I found my oil leak (maybe not sump after all) Pics
 Post subject: Think I found my oil leak (maybe not sump after all) Pics
Posted: Tue Oct 17, 2006 1:31 pm
Ride: E39 523i / EF Fairmont
Well when I did my service today, I got to the stage where I was changing my oil filter and found this disturbing sight.
Unfortunately the picture isn't clear where the oil is, but I can describe it as fresh and a considerable amount there.
It is where those bolts are that hold that weird thing with 6 chambers on the right-hand side of the block.
Anywho, what is my problem now, and how much?
File comment: Lame
E39 523i
EF Fairmont
Posted: Tue Oct 17, 2006 1:34 pm
Ride: 1989 300ZX Twin turbo Z32
the wierd chamber thing you refer to is the BBM intake manifold. If oil is leaking around here it could also be the headgasket as the head joins the block very close to that area. however if its not leaking a huge amount you could probably try some gasket sealant (or something similar) and attempt to seal off the area thats leaking from the outside
also dont rule out the rocker cover leaking (it could just be leaking down from the rocker cover down onto the manifold.
Sold my EB :(
Now got my 300zx :)
Posted: Tue Oct 17, 2006 9:03 pm
Um, no one else wants to say anything? lol.
E39 523i
EF Fairmont
Posted: Tue Oct 17, 2006 9:07 pm
Think bluecube covered it
Posted: Tue Oct 17, 2006 9:10 pm
in that pic the head gasket is dry. that looks like fuel. hook your finger around the bottom of the manifold and smell it. u'll know if it's fuel.
<a href="http://www.spyderbyte.com.au">
<img border="0" src="http://www.spyderbyte.com.au/updated.gif" width="189" height="45"></a>
Posted: Tue Oct 17, 2006 9:36 pm
The BBM is above the head gasket so you must have some wierd physics going on if thats the problem.
Could be oil from the rocker cover gasket, but I dont see it anywhere else.
I would tend to think those are stains from from fuel and oil pooling in the ports and leaking through the gasket.
Posted: Tue Oct 17, 2006 9:39 pm
is that pic taken from underneath ?
does this mean you hopped in the engine bay and shut the bonnet and took the pic ? :lol: :lol: :lol:
2000 AU2 FUTURA WAGON
Posted: Tue Oct 17, 2006 9:49 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
Clean it.
Tighten the 10mm bolts from the inside to out.
Reinspect in a couple of days.
the inlet gasket compacts and becomes loose and thats most likey the result of the oilish residue.
Posted: Tue Oct 17, 2006 9:59 pm
Tighten the bolts from the inside to out? wtf. Do you mean tighten the bolts?
If you do, will do. Not sure how I'll access them, but I'll try, lol.
E39 523i
EF Fairmont
Posted: Tue Oct 17, 2006 10:06 pm
Ride: FGX G6ET
Inside to out....start with the inside bolts and work out...
Posted: Tue Oct 17, 2006 10:08 pm
Ride: EF Falcon
yeah
start at middle out and work you way out
middle of motor to back of motor to front of motor
top and bottem
EFBIGNIK 145.9 RWKW Falcon / 16.27 @ 86.72mph (Stock)
http://s60.photobucket.com/albums/h38/e ... urnout.flv
Posted: Tue Oct 17, 2006 10:14 pm
And dont go crazy tightening them either as the bolts are going into an alloy head
Posted: Tue Oct 17, 2006 10:18 pm
Ride: Isuzu MU-X ,2018 Kia Cerato
might pay to check all your bolts dround the engine, once noticed that a slight weep turned into a drip and found at least 3 sump bolts finger tight on my fairmont.
'96 DF II LTD 6cy
'15 Isuzu MUX LST
Posted: Tue Oct 17, 2006 10:51 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
I'd be more concerned with the glycol seap on your heater pipe!
just thought I'd point that out!
Users browsing this forum: No registered users and 62 guests
It is currently Wed May 21, 2025 8:16 pm All times are UTC + 11 hours
