Damn Car Wash - Killed engine
Page 1 of 2 [ 27 posts ] Go to page 1, 2  Next
 Post subject: Damn Car Wash - Killed engine
Posted: Sat Oct 14, 2006 10:17 pm
Ride: EL Fairmont
Hi Folks,
My mate just took his EL Fairmont to the car wash, and thought he'd use the high pressue water to blow away any dust in engine bay.
After doing that, he started the car, but it wouldnt idle right. He drove forward to the vacume bay, and it stalled when he placed it back in P.
Now, it just wont fire up. It turns over, but theres no spark.
We've cleaned out all the plugs and connectors we could get to, and have let the car sit for a few hours, but it still just wont fire. Any tips how to get it cooking again ? what should we check next ?
Is there any easy (or hard) way to test the Distibutor or Coil pack ?
Posted: Sat Oct 14, 2006 10:24 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
take off the dizzy cap and spray some WD in there.
also... EL's run a Coil, not a coil pack... these (most likey) have a crack in them, and a small amount of water will make them miss fire and or die completely
displace all the water you can and dry it... WD does wonders.
Also check the plug holes... they don't like water either.
I'd put my money on the coil... very common to do this.. if you don't know where its exactly located... its just above the passenger engine mount.
Posted: Sat Oct 14, 2006 10:25 pm
Gallery: 5 images
Ride: 2021 Amarok V6
lol this happened to my mates XF EFI, we sprayed CRC 5.56 around the spark plugs and stuff, and it started and revved at 3000rpm for like 5 minutes :lol:
Posted: Sat Oct 14, 2006 10:28 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
yeh as above, when he does get it started... give it a flogging!
Posted: Sat Oct 14, 2006 10:29 pm
Gallery: 5 images
nah we sprayed that much in there, it revved by itself at 3000rpm for 5 minutes lol
Posted: Sat Oct 14, 2006 10:38 pm
Ride: BA xr8 Magnet ute
you should sue them :P
Posted: Sat Oct 14, 2006 11:05 pm
Ride: 2010 Nitro Blue FG
Also check the TFI module as if that has any water or moisture in it, it wont fire at all.
The boogieman checks under his bed for chuck norris
Posted: Sun Oct 15, 2006 12:59 am
NEVER EVER USE a high pressure hose inside the engine bay for the above reasons
a garden hose is all that is needed
RIP SCOTT
Posted: Sun Oct 15, 2006 2:07 am
Ride: EL Fairmont
Thanks Folks. I think you could be spot on with the coil there. It's just such a dog to get too. He's going to kick it over in the morning and see what happens. Otherwise we might haul over some car ramps and see if it's easier to pop it off from underneath.
Frank: He knows that now, thats for sure!
It was actually an odd thing, we had one EL fairmont towing another! Should've taken a photo. :)
Posted: Sun Oct 15, 2006 10:18 am
To replace the coil do it from underneath it is far easier.
Posted: Sun Oct 15, 2006 11:42 am
Ride: E39 523i / EF Fairmont
What the s**t, a high pressure hose on an engine bay? What an idiot.
E39 523i
EF Fairmont
Posted: Sun Oct 15, 2006 2:07 pm
Ride: 2009 FG XR6 Sedan
You can use high pressure on the engine but it must be cold, the coil does get hot and if it hasnt any cracks yet it sure will after cold water hits it. To be on the safe side do it when engine is cold and place a plastic bag over the dizzy and the coil.
Posted: Sun Oct 15, 2006 2:49 pm
I carry 2 cans of "mechanic in a can" under the seat all the time. after I high pressure clean the s**t out of the engine bay, I'll literally spray anything thats electrical before I even start it up, it never fails to start a second of turning the keys.
Mind f**k!!! it works on feeble minded ignorant sheeples... there's plenty of em on this site... some are very intelligent but by god they are so thick!!!
You can buy them seppertly
Posted: Sun Oct 15, 2006 3:21 pm
Ride: 2.0 Turbo VW
Power: 142 rwkw
I cant say I'm over cautious.
I pressure wash my engine regulary (not that it gets dirty)
I've never had any starting problems ever!
Only bad thing pressure washing did was leak water into my 308 via the inlet manifold. This made me flush 8ltrs of s**t oil through it! and it lived to see another 3+ yrs!
Posted: Sun Oct 15, 2006 5:47 pm
i do it several times a day at work and dont have any issues. u just have to know what u can and cannot get wet. a garden hose is plenty to soak compnonets beyond function.
if the coil has a crack, a rainy day is enough to expose it.
<a href="http://www.spyderbyte.com.au">
<img border="0" src="http://www.spyderbyte.com.au/updated.gif" width="189" height="45"></a>
It is currently Sat May 17, 2025 11:02 am All times are UTC + 11 hours
