SwiftAU |
I recently got my au s2 on duel fuel (gas) the first problem is on gas acelerating its very jolty like go stop go stop all the time iv changed the plugs , leads and fixed any air leeks and its still there it s@iting me up the wall and iv even had a gas tune up and its still there . ok second problem is on petrol on take off its very slugish till it gets to about 30 km and then it takes off like a shi@ out of a shanghi i changed the fuel filter and now im out of ideas what could it be tryed octane fuel , still there and im sick of it if theres anyone out there that can help please reply to this forum thanks
benno's ed |
What is the temp gauge reading. Is your thermstat working properly.
smiley235 |
as i mentioned in your other post, have you checked to make sure the butterfly on your BBM is working properly.
_________________ 178.3 rwkw
SwiftAU |
my temp is fine its nothing over half but somtimes whn i stop after a drive my temp gage reads normal and the radiator top up is boiling but not tomuch water comes out the overflow hose
SwiftAU |
whats the bbm ? is that the throtel body ???
smiley235 |
bbm stands for broadband manifold. Its your intake manifold. It has a butterfly which changes the length of flow at about 3000rpm to give more power. However, when the car is off, its set at the high rpm position until it gets power so if its not hooked up correctly, you will be lacking power below 3000 rpm. To check it, Get someone to start your car whilst your looking at the bbm butterfly and see if it changes position when the car is started.
SwiftAU |
so is the buterfly visabul form the out side on the manafold
SwiftAU |
so how do u know if it works proply what should it do
SwiftAU |
it dident move when it was reved how do i fix it but it did move when the car started please how do i fix your a fing leadgend
smiley235 |
well, technically the butterfly is an internal device however is connected to a visible lever which you can see move an either move with you hand (looks like a throttle lever a bit).
I quickly got some photos from my car just then to show you, sorry about the darkness as night has arrived. Here is a far away shot so you can see where it is located: ![]() And here is the position of it when the car is started (I've pushed the lever down with my finger. ![]() Here is a shot with the position its in with the engine off. ![]()
SwiftAU |
please tell me i can fix it now please this has been giving me the absoult sh*ts your a top block not many people help others like that cheers mate
smiley235 |
np, plenty more helpful people here, they will help you from here as I'm not 100% sure on what the problem is. Check that the solenoid is hooked up to the PCM?? i think (like in my pic). It should run to a box to the right of that.
Don't worry, you'll have your answer soon enough.
SwiftAU |
whats the solinod and where abouts dose it go to
smiley235 |
SwiftAU |
its diffent on the au s mine go \se to the back of the windo wash resevor to a little thing there it sucks air when i diconect it the buterfly opens up in the positon its like when the motors turnd off i took it fo a quick spin and i think it has resolved the jolting problem on gas but it has made little to no diffrence to the take off on petrol so back to squre one
Users browsing this forum: No registered users and 30 guests |
