Cam change
 Post subject: Cam change
Posted: Fri Dec 08, 2006 7:35 pm
Ride: ED Fairmont
Afternoon all,
I'm having some work done on Monday, and I was hoping to elicit some opinions on how everyone thinks it'll affect power..
Current set up -
Crow EA-ED Wild Performance Cam (222825)
EA-EF Vernier adjustable timing set (CS6EA-VS)
Falcon XR6 valve springs (7739-6)
2 1/2 inch Pacemaker extractors, 2 1/2 inch high flow redback cat & mufflers (PH4499, STR110, 2T3870TP)
Ported & polished Cyl Head,
Unichip computer
With this set up, I hit 130rwkw on a dyno about a month ago.
Monday I'll be adding:
LSD with 3:5 gears
Stage 5 Crow cam set up. (2222543)
Keeping the Auto - it's only done about 20,000kms.
Car will be tuned at Fitzgerald Racing Services (Box Hill).
Typically they work with Porsche's, but they're willing to tune the Fairmont.
Unichip tuners are getting harder to find :/
So, predictions anyone?
Speed. Is there anything that compares?
Posted: Fri Dec 08, 2006 8:05 pm
Ride: ef fairmont turbo
Power: 213 rwkw
my guess will be at 145rwkw, its hard to get much more then that with an auto
96 EF FAIRMONT
Garrett gt40turbo, iceman plenum, ported head, turbo cam, double valvesprings, 023 fuel pump, 36lb injectors 4' cat, 4' dump, 2.5 exhaust, build bottom end, hypertonic pistons rods & rods, king bearings, j3. c10 3500 stall
232rwkw@4psi
Posted: Sat Dec 09, 2006 6:47 pm
Ride: ED Fairmont
bump - curious as to opinions..
Posted: Sun Dec 10, 2006 1:40 am
Ride: 66 Coupe
Its probably too much cam for an auto with standard converter. I would go 3.7 or 3.89 gears, instead of 3.45's, you will be much better off, and will allow you to get the revs up a lot quicker.
It is currently Sun May 18, 2025 3:49 am All times are UTC + 11 hours
