ef mick |
hi guy would love to know if a au engine fits into a ef fairmont any help or pic would be great or if theres any site i can look at let me know and can it be done will the gearbox fit or will have to put in au gearbox in iswell
thanks mick |
GeZza200 |
They would drop right in, if it wasn't for the sump. You can mod the sump or mod the K frame. There are quite a few threads on here about the conversion. Just use the search up the top of your page and im sure you will find what your looking for.
_________________ EL Futura: CVE head, Wolf V500, ICE Ignition and Coil, 36lb injectors, Walbro 255lb, Paci comps, 3" exhaust, T5, Harrop Truetrac with 3.9s. Now with 198.9rwkw, (~185rwkw and 13.80 @99.1mph) with more power to come |
Krytox |
yes, engine will fit woth sump or cross member mods.
use the search feature, its covered about 2,000 times.
ef mick |
thanks for ur help what site though i cant find it ???
GeZza200 |
Heres an EF with the modded K Frame
http://www.fordmods.com/forums/my-au-en ... ght=welder
ef mick |
thanks mate
ef mick |
also can i run ALL au running gear
GeZza200 |
The trans is the same, im not sure about the diff though.
ef mick |
and the au computer is ok to use? i know i hav to change all the wiring
FORDom |
use your ef ecu..
easiest way is to buy a modified sump from the company in qld (about $300 to your door) |
Users browsing this forum: Google Adsense [Bot] and 60 guests |
