Grechie |
Hey Guys.
I've been told many times to reset my ecu now that i got the new cam, but i am hesitant to do it, shouldnt it relearn new mixtures or will it just plain be up the sh11t coz its been mucked round to many times? the timing has been fiddled with many times (advanced, de advanced, advanced etc), a different cam has been put in, and a new oxy sensor has been put in, and havent reset it at all since i first put the motor together. Is the ECU not adjusting (running fairly rich now) and is just thinking somethigns wrong and is tryign to compensate, or will it be fine leaving it how it is. Thankx - Grechie
_________________ Ford Falcon EA Naturally Aspirated 4.0L i6 |
stockstandard |
Resetting the ecu is rarely needed, but usually it doesnt hurt to do it anyway. The ECU will always adapt to the engine, it is just that it 'learns' at a faster rate after a reset.
Grechie |
how long we talking if i dont reset it ? all i know is, when we played with the timing, the car now when warm throws fuel on startup, but not on cold, even on stock timing it does it , so it cant be the actual timing, maybe the ecu is just in need of one ?
Steady ED |
I am yet to see an E-Series 4L that doesn't dump fuel out the exhaust on starts, cold or hot.
Could take a week to learn, could take less, the whole "ECU reset" thing is made out to be alot more important then it actually is.
fordzatmyplace |
{USERNAME} wrote: I am yet to see an E-Series 4L that doesn't dump fuel out the exhaust on starts, cold or hot.
Could take a week to learn, could take less, the whole "ECU reset" thing is made out to be alot more important then it actually is. exactly. When i have my battery disconnected, and then go for a drive, it behaves in the exact same way ![]() I think thats mabey becuase i have no really major mods though
_________________ ^^^ What He Said
fordebgt93 |
would you need 2 reset ECU if u only change ur cam and nothing else
_________________ i smell bad even when fm members drive past lol. |
Steady ED |
{USERNAME} wrote: would you need 2 reset ECU if u only change ur cam and nothing else
You don't ever "need" to reset the ECU. If you reset it, the ECU will "learn the cam" quicker, but if you don't it will eventually learn anyway. So yes, its a good idea, but if you don't, it won't do any harm, EEC is pretty smart.
fordebgt93 |
at what stage if any would u need 2 reset ecu
Steady ED |
What do you mean?
It's not a massively important thing to do it at the "right time", or even at all.
fordebgt93 |
yeah ,i just did,nt know when or if it had to be done .Just taking a keen interest
Mitch_ |
Posts: 6168 Joined: 5th Nov 2004 |
{USERNAME} wrote: {USERNAME} wrote: I am yet to see an E-Series 4L that doesn't dump fuel out the exhaust on starts, cold or hot. Could take a week to learn, could take less, the whole "ECU reset" thing is made out to be alot more important then it actually is. exactly. When i have my battery disconnected, and then go for a drive, it behaves in the exact same way ![]() I think thats mabey becuase i have no really major mods though i find mine stalls at lights when i first reconnect the battery, after about a week its fine though! {USERNAME} wrote: What do you mean?
It's not a massively important thing to do it at the "right time", or even at all. at the third stroke of midnight acutally, on a full moon!
fiftyone |
just do it. you've put a cam in so you shouldn't be worried about chooing fuel.
besides. get the engine hot, run it around the block twice. put it in park with the hand brake on and run the AC for a bit. 10 minute job
fordzatmyplace |
{USERNAME} wrote: i find mine stalls at lights when i first reconnect the battery, after about a week its fine though!
you got a stinky EF, so you don't count ![]()
Grechie |
im not just a reseetingg a ecu junky guys, i expolained i had timing up and down quiet alot new oxy sensor and a new cam to the old wade i had, and as far as i was concnered the ecu was running sick
bfturb |
{USERNAME} wrote: {USERNAME} wrote: would you need 2 reset ECU if u only change ur cam and nothing else You don't ever "need" to reset the ECU. If you reset it, the ECU will "learn the cam" quicker, but if you don't it will eventually learn anyway. So yes, its a good idea, but if you don't, it won't do any harm, EEC is pretty smart. smarter than you aint it jared
_________________ No dose No Care |
Users browsing this forum: No registered users and 46 guests |
