longlivethefalcon |
where is the adjustment for the serpentine belt on an EF to tighten?
_________________ Mk2 Zephyr |
...Dunkly |
I think they have automatic belt tensioners, you just need to use a socket or a spanner to lever it across and then just release it once you have the belt on and lined up
ovo616 |
no their is a tenisoner pulley that takes up any slack in the belt
Linzo |
All you need is a 3/8 ratchet or strongarm bar to relieve the pressure on the belt. Slip the old one off and whip the new one on simple as. You can remove your thermos to if you want to make it easier. So going on your origianl post you cant really adjust the tension on your belt. It sounds like yours is pukered. Get a new belt
Gaz |
yep, its self tightening.
if ya belts loose then its probably stretched.
cjh |
{USERNAME} wrote: where is the adjustment for the serpentine belt on an EF to tighten?
Why do you need to tighten the belt????? They are automatic.
Molloy |
{USERNAME} wrote: {USERNAME} wrote: where is the adjustment for the serpentine belt on an EF to tighten? Why do you need to tighten the belt????? They are automatic. Tensioner could be rooted??
