Glowing EF |
can anyone explain to me if possable with pics how to hook up and oil pressure gauge, i got no idea where to plug the sender in. LOL its for an ef i6
braidy |
http://fordmods.com/forums/viewtopic.php?t=49384
_________________ RIP Chelsea |
Glowing EF |
big help, thank you
Glowing EF |
just quick question, for the air ratio, when you say "splice into the oxygen sensor" do you mean the wires that are connected to the sensor or the plug and on the gauge i have to cut the end sensor off, right?
66 coupe |
{USERNAME} wrote: just quick question, for the air ratio, when you say "splice into the oxygen sensor" do you mean the wires that are connected to the sensor or the plug and on the gauge i have to cut the end sensor off, right?
Connect the gauge to the 02 sensor wire at the ECU harness, will save running a wire into the engine bay |
Glowing EF |
which ones are the 02 wire in the ECU harness?
66 coupe |
EF 6cyl Ecu pin 35, Dark Green / Dark Blue wire, 2nd row of pins, 9 wires in from the end
67RCE |
The only problem is, E-Series use a narrowband o2 sensor, for an accurate AFR, you need a wideband o2 sensor
Glowing EF |
66 coupe so is it just those 2 wires the dark green and blue and thats it?
66 coupe |
one wire mate, dark green with a (dark) blue stripe
Glowing EF |
so cut the end part off the cable for the oil pressure and connect it to the dark green wire? right
stomper |
{USERNAME} wrote: so cut the end part off the cable for the oil pressure and connect it to the dark green wire? right
If im readng right then no BUT If it says splice that means remove some on the wire insulation and solder another wire to that and then use tape to insulate the wire again. The other way to do it is cut the wire and strip all three and solder them all together BUT to make it neat i would put 2 wires together and join that to the single wire. Ben
_________________ HOLDENS go like rockets. They fall apart in stages!!! |
66 coupe |
hang on, you talking about the A/F ratio gauge or an oil gauge?
Glowing EF |
lol in regards to 66 coupe , oil pressure
66 coupe |
Well whats this air ratio / oxygen sensor post about. Oil pressure you need to cut into the oil gauge wire behind the cluster, and use only a single oil pressure gauge, therefore if theres one in the cluster you need to disconnect it, or if you currently only have an oil light, then you need to disconnect that and use the gauge with the correct sender. |
Users browsing this forum: No registered users and 52 guests |
