4nik8 |
_________________ save petrol and reduce congestion....bury all holden |
phongus |
You might want to check your vacuum hoses. pop the bonnet and check if the vacuum hose that runs into the cabin is put in correctly and that its not loose. if not you might want to pull off the glove compartment and see if you need to replug in the hoses from there...only thing i can think of that controls the vents.....thats assuming you have CC....and I think it goes the same for non CC.
Walker |
I hope it's not the blend door, a b**ch to change.
I'm just going from memory here, but that's a very common problem. |
4nik8 |
ok thanks guys,hmm i did take the glovebox out when i fed the bbm wires thru, il take it out and have a look,,,i thought it may have been electrical.
andrewts |
{USERNAME} wrote: I hope it's not the blend door, a b**ch to change.
I'm just going from memory here, but that's a very common problem. Nah, that's for how and cold anyway isn't it? If it hasn't got Automatic Climate Control then the blend door is operated by the temperature knob as well. This sounds more like there is a vacuum cut-off valve that has failed, so whenever there is vacuum the vents close, and whne the vacuum drops off (after killing the engine) the vent swings back open like a toilet door. Don't quote me, I have no experience and I am guessing. ![]() |
Krytox |
Check the flap under the passenger side (behind the glovebox on the left)
put ur hand up there and if you move the flap and leaves fall... its dead. if it springs back.. theres a vacuum problem and disreguard anything i wrote :P refer: http://www.fordmods.com/forums/documents.php?doc=23 cheers?
4nik8 |
well i couldnt get my el computer to go into diognostic so i ended up putting the eb ecu back in ,,nw its working fine
snap0964 |
Looks like it's an EL police ECU - going off http://www.fordmods.com/forums/viewtopic.php?t=30186 (if it's accurate).
Should still be able to be put into diag mode as per all the others (correct me if I'm wrong).
4nik8 |
thanks for that link .. police ecu..i thought it was from an xr..i have the option of trying a 6TBA,,,but i not see it on the list
4nik8 |
ive found that if i clear the fault codes then the vents wil work ,as soon as u turn car off and turn ignition again then vents close again,this is the same with both EL computers..but again not with the EB computer..
