engine blowing black smoke
Page 1 of 2 [ 24 posts ] Go to page 1, 2  Next
 Post subject: engine blowing black smoke
Posted: Mon Jul 30, 2007 6:21 pm
Ride: Xr6 Turbo
hi all, well today my car started running like a dog, smooth idel, but blowing black smoke, not oil brning smoke (blue colour) its like black. also its spitting out black liquid!! im so confused what do you think it is???
Previous cars
1995 ef futura - nothing special
2003 xr6 turbo 5 -speed 307rwkw
Posted: Mon Jul 30, 2007 6:31 pm
Power: 144 rwkw
I believe the head gasket has died. and I think it may be oil burning with a tad of water mixture. hence the black smoke with black soot in water (black liquid). Or the black liquid could just be condensed air vapour trapped in the exhaust over night and mixing with burnt carbon.
but I'm no expert.
phong =P~
EDIT: Or what smiley said below
phongus = Post whore 2006
Ride: BA Falcon Suzy Across
Power: 178 rwkw
the cars running rich, unburnt fuel is exiting the exhaust pipe. You probably notice less power and more fuel consumption. Could be the oxygen sensor.
178.3 rwkw
15.1@96 mph
Now with 3.9 shrooms
Posted: Mon Jul 30, 2007 6:46 pm
Ride: Xr6 Turbo
ahhh thanks alot for such quick responce, its not the head because that was done less than 5000 kms ago, i think oxy sensor is the way car has done 229000 ans never had it replaced. again thanks and had quarter of a tank only lasted me 60kms or less
Previous cars
Posted: Mon Jul 30, 2007 7:36 pm
the hose to the map sensor connected ?
Posted: Mon Jul 30, 2007 7:42 pm
Ride: 1993 EB XR8
Map sensor hos or oxy sensors f**k
Posted: Mon Jul 30, 2007 7:57 pm
Ride: 1994 ED Fairmont
Map sensor, Oxy, Coolent sensor.. MAYBE...
1994 ED Fairmont Champaign Gold - AU Series II Intech 4.0L - EL EFI - Thermo Fans - 4.11 LSD - Pacemaker 4480 Into Custom 3" Exhaust - Shift Kit
In Progress: EL 4 Speed Auto- 3000 STALL - To be fitted
EF Tickford Race Spec Head Port- In the shop
Custom SureCam - Chiptorque
Posted: Mon Jul 30, 2007 8:22 pm
Ride: R34 GTR
the "black liquid" is just water mixed with the carbon ash in the exhaust.
My bet is O2 sensor.
LUMPY-6
Posted: Tue Jul 31, 2007 1:14 am
Ride: BA XR6 Turbo
My bet is the hose to the map sensor.
We forgot to refit this when changing the TB on a mates VR and it idle'd like a cam'd V8, but with black puffs of smog coughing at the tailpipe..
I like boost
Posted: Tue Jul 31, 2007 10:04 am
Ride: Xr6 Turbo
o ok then well i poped the bonnet up and had a look around the engine pay and could not find any loose or taken off hose, but i must admit i dont no what im looking for i no it sounds just stupid but i dont no, can anyne post a pic up or the map sensor and hose that it connects 2. thanks alot
Previous cars
Posted: Tue Jul 31, 2007 5:09 pm
Power: 178 rwkw
exact copy off one of my old posts:
Quote:
Hey, ignore the tennis raquet cause your is probably mpfi, the map sensor is the little black box at the top of the pic and the tube coming out from it connects to somewhere like the intake manifold or throttle body (can't remember 100%) but just look out for an empty protrusion that the hose would fit on, usually looks pretty obvious.
178.3 rwkw
15.1@96 mph
Posted: Tue Jul 31, 2007 6:37 pm
Ride: Xr6 Turbo
hehe yeh i found it. well nothing in unpluged all ok. i think its oxy sensor.
Previous cars
Posted: Tue Jul 31, 2007 7:03 pm
Ride: 94 EF (OPT20), TF Cortina Ghia
Doesnt mean its not the head again. did you have the head done by a reputable mechanic. if all the other things mentioned above are ok then i would agree with Phongus that the head may have died again. Head bolts may not have been torqued down properly.
"Look I found tape, I'm a mechanic now!!!" Mike Teutul
Posted: Tue Jul 31, 2007 7:29 pm
Ride: Xr6 Turbo
no my dad did he, and we have a kinkrome torque wrench. he has been workin on generators his whole life, so it was done properly. and timing was done at the same time, aswell as new bolts. but as u said may of happend again. will get dad 2 look at it. but cannot see any coolant wheeping and level is the same. and oil hasnt droped
Previous cars
Posted: Tue Jul 31, 2007 7:57 pm
Power: 178 rwkw
Well change that o2 sensor. If that doesn't fix it, could be a number of things, even a leaking fuel injector for example!!
178.3 rwkw
15.1@96 mph
Users browsing this forum: No registered users and 73 guests
It is currently Fri Jun 06, 2025 3:20 pm All times are UTC + 11 hours
