AU Engine Transplant
Page 1 of 1 [ 8 posts ]
 Post subject: AU Engine Transplant
Posted: Mon Nov 12, 2007 10:43 pm
Hey Guys,
I have recently come into ownership of an AU Tickford engine and am thinking of putting it into my EF.
So far i have researched the following mods i will need to do.
modify sump
au alternator
ef thermo housing
ef aircon compressor and spacers
ef intake and harness
ef oil pressure sensor(xr dash)
ef intake gasket
au sump gasket
ef thermostate housing gasket
au plug and wire for the knock sensor
ef cam angle sensor (the dizzy thing)
au fan belt
Due to the fact that its a tickford engine does this mean i will need to change ECU's???
Anything i have missed??
Posted: Tue Nov 13, 2007 6:59 am
Ride: 2007
Bell housing.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Tue Nov 13, 2007 10:04 am
Ride: EBII 220kw Tickford powered.
I do not think you will need to change the bellhousing.
I put an AU 6cyl into my wifes EA, no bellhousing change required
The car should be called "Frankenstien". EBII GLi skeleton, AU T2 220kw heart, AU2 brain, EF/EL for everything else.
"Bitza" Member 28 on FORDMODS v1.0 Joined 28-04-2002
"TS50EB" Member 300 on FORDMODS v1.1 Rejoined 6-11-2004
Posted: Tue Nov 13, 2007 10:36 am
Ride: BA MKII Futura
2 of the bolts dont line up with the e series bell housing however (not with boxcars at least) to get the extra 2 bolts to fit you need the au bell housing.
Posted: Tue Nov 13, 2007 7:13 pm
Are the bellhousings on the auto gearboxes detachable/interchangeable?
Posted: Tue Nov 13, 2007 8:04 pm
Ride: 2007
Yes they are interchangeable in that the BTR box will bolt up to either but the motor end is different between A series and E series. As mentioned the 4 bottom bolts are different and 2 of them plain won't fit.
There are a few (maybe most) that don't worry about it but if you are pedantic like me you need the bellhousing as well. BTW I found retaining the E series knock sensor the best but you need to make an adapter to fit it to the block.
,======o00o
Posted: Tue Nov 13, 2007 8:06 pm
There are a few (maybe most) that don't worry about it but if you are padantic like me you need the bellhousing as well.
Looks like im in the market for a bellhousing, im not doing this on the dodge :)
Does anyone actually sell already modified sumps for AU's?
Posted: Tue Nov 13, 2007 8:27 pm
I think this mob used to do the sumps but not sure if they only supply them with their motors. You can always ask them if they will sell you one seperate. Anyone know what they charge for a modified sump alone?.
http://cgi.ebay.com.au/Good-low-K-AU-Fa ... dZViewItem
Users browsing this forum: Google [Bot] and 131 guests
It is currently Tue Jun 10, 2025 1:58 pm All times are UTC + 11 hours
