Running E Gas motor on petrol?
Page 1 of 1 [ 7 posts ]
 Post subject: Running E Gas motor on petrol?
Posted: Mon Jan 21, 2008 5:21 pm
Gallery: 40 images
Ride: EF GLi/Ghia bitsa
My mate got given an AU E Gas engine with low k's on it, and we are tempted to fit it to his EL that has a tired motor. the EL is dual fuel, but how well will the E Gas motor run on PETROL if we bolt up all the EL Manifolds, dissy etc? Is it likely to run ok on both fuels? it's just a BARE engine with no accesories so we'll be using everything off the EL. Will this work?
Gab
Posted: Mon Jan 21, 2008 5:59 pm
Ride: ef 5 speed
it should work in theroy because the au e gas motors didnt have the ingetors on the manfolds so if you use the el one it should be ok same block but a little less power
i am in need of a new front bar or good condation secondhand for a 95 ef futra,
lsd for a for ef ,modifed au sump to go in and ef , working air con compressor
Posted: Mon Jan 21, 2008 8:40 pm
Power: 174 rwkw
may need to run premium as i think the e gas may have got a hike in compression. not sure though.
Posted: Mon Jan 21, 2008 9:21 pm
thats all i can think of as well
should motor along nice
RIP SCOTT
Posted: Tue Jan 22, 2008 12:30 pm
Gallery: 40 images
If the compression is higher, and we only run it on premium or LPG, shouldnt it theoretically go better than a normal motor? will it go as good as a Tickford engine?
Gab
Posted: Wed Jan 23, 2008 2:21 am
Gab
better than normal yes
might gain 5hp or so if that
tickford hahahahah NO WAY
the tickfords had diff cams and valves for 1 and different ecu programing
now throw in a nice cam and extractors and zorst, new diff ratio, high flow air filter etc
u should see a gooood improvement just like any car
RIP SCOTT
Posted: Wed Jan 23, 2008 5:12 am
Ride: 94 ED Fairmont, MY97 LE WRX
Didnt a E-gas motor have a gas cam, different valves and ecu?
And isnt it about 30 odd Kw's down on the standard pertrol motor?
Users browsing this forum: Facebook [Bot] and 72 guests
It is currently Mon Jun 09, 2025 1:54 am All times are UTC + 11 hours
