Temp problems
Page 1 of 1 [ 5 posts ]
 Post subject: Temp problems
Posted: Mon May 05, 2008 12:53 pm
Ride: Au XR6 VCT
G'day having a problem with my 98 au xr6. sometimes when i kick the old girl over the temp guage will jump straight to hot. The engine is not hot because it is only just kicked over and the block is cold to touch. I have replaced the thermostat but has not fixed the problem. I have been told it could be a dirty sesor. Any suggestions?
cheers john
Go the mighty blue oval!!!!!!
Posted: Mon May 05, 2008 2:38 pm
Gallery: 20 images
Ride: XH Ute / AU3 V8 Wagon
First, check the gauge. Remove the wire from the temp sender, turn the key to "ON" and short the wire to earth. If the gauge goes to HOT, it's working fine. If not, you have a screwy gauge. If the gauge is OK, replace the temp sender and see what happens. There not expensive or difficult to do.
Good luck, and let us know how you get on. :D
XH Ute Thread {DESCRIPTION}
Posted: Mon May 05, 2008 5:51 pm
Ride: Au XR6 VCT
thanks champ was even thinking too of hooking up an autometre temp guage. but i'll do this and let ya know whats doin
cheers john
Posted: Mon May 05, 2008 6:41 pm
Ride: AUII XR6 Uterus
yes i to have a guage fetish but a guage won't fix your troubles :P
Posted: Tue May 06, 2008 4:12 pm
Ride: Au XR6 VCT
yeah i know but it will help me monitor it just in case it does over heat and i ignore it plus they look f**k cool
Users browsing this forum: No registered users and 61 guests
It is currently Fri Jun 06, 2025 12:34 pm All times are UTC + 11 hours
