xfpaul |
anybody know why the ea-el thermo has a spring load valve on the bottom of the thermo and the au2 doesnt
_________________ NC2 Fairlane AU2 Intech 4.0 Wolf V500 ECU Accel 500cc Injectors Eaton M90 Blower MPx Porting 75mm Mustang TB Intercooler Holley 255lph EL XR6 Rear End 3.45 LSD Duel Fuel lots more. |
xfpaul |
maybe not
AU2SR |
au update did not have one
_________________ Technical Advisor AA GASKETS |
TROYMAN |
i heard a rumour that the spring plate on the lower part of the thermostat was restricting water flow to the heater hose pipe that runs off the lower thermostat housing?
AU2SR |
{USERNAME} wrote: i heard a rumour that the spring plate on the lower part of the thermostat was restricting water flow to the heater hose pipe that runs off the lower thermostat housing?
yes that is what it was designed to do but on the later e-series and from then on it was deleted cars on lpg should have that bypass removed as well fro better flow to the converter and for fuel maps for the lpg
Users browsing this forum: Google Adsense [Bot] and 35 guests |
