MOVE THROTTLEBODY
Page 1 of 2 [ 22 posts ] Go to page 1, 2  Next
 Post subject: MOVE THROTTLEBODY
Posted: Sat Mar 08, 2008 8:03 pm
Gallery: 5 images
Ride: 03 BA
OK hears a thought has anyone done this or ma b some one should do this , move the throttle body over 180 degrees to face left side car then it would be a short an fairly straight run to air box if i new how to weld the stuff id try . wat do the rest of ya think ma b some one out there can try
Posted: Sat Mar 08, 2008 8:49 pm
I have seen it done but IMO there is not really any point to it. A big volume of air between the throttle body and the filter is actually a good thing.
Posted: Sun Mar 30, 2008 10:19 pm
Ride: BFII Turbo
Power: 253 rwkw
how big is the throttle body on an AU and how big can you go? are the ones on the BA XR6's any larger?
enough isn't enough
Posted: Sun Mar 30, 2008 10:53 pm
ACT Cruise Moderator
Ride: '06 BF GT-P
Power: 293 rwkw
The B series throttle bodies are all "fly by wire" (electronic). No good for pre B series.
Posted: Mon Mar 31, 2008 9:58 am
Gallery: 34 images
Power: 225 rwkw
have seen it done on a black i6 na ba.. throttle body reversed.. and running at wsid.. a member of FF...
Posted: Mon Mar 31, 2008 9:10 pm
97 EL Fairmont 4l OHC .Silver.
Exhaust: Pacemaker's, 2.5" exhaust and Hiflow cat
Intake: FRAM AIRHOG , EL GT snorkel
XR6 300kpa fuel reg Stg 2 Auto Shift Kit.6DJA ECU
PM in Qld looking too buy Toyota 4*4 SR5 Dualcab Hilux 91-97 with 2.8l diesel engine/5spd manual
Posted: Mon Mar 31, 2008 9:42 pm
Gallery: 17 images
Ride: TS40
looks dodge :D
Was - {DESCRIPTION}
Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior
Now - {DESCRIPTION}
Swift Green,6 Speed Auto, Stock... and a Fuel Card :)
Posted: Mon Mar 31, 2008 10:04 pm
Ride: '06 BF GT-P
Power: 293 rwkw
What you expect him to cast a fresh manifold. :)
Posted: Mon Mar 31, 2008 10:07 pm
isn't the FG new plastic intake manifold throttle body facing that way ?
Posted: Mon Mar 31, 2008 10:41 pm
Gallery: 5 images
Ride: R33
Power: 142 rwkw
wonder if there interchangable with e series, the FG manifold that is.
R33 GTS-T - 222.6rwkw
EF - 142rwkw
Posted: Mon Mar 31, 2008 11:32 pm
Be good to know this one~
Posted: Mon Mar 31, 2008 11:39 pm
Ride: '06 BF GT-P
Power: 293 rwkw
As the B series manifolds aren't compatible I'd say the FG ones aren't, unless they went back (backwards?) to E and A series style ports.
Posted: Tue Apr 01, 2008 12:06 am
Ride: EL fairmont offroader
I was only wondering the other day why they didn't go that way in the first place. Is the idea of having more air about having a ballast effect, momentum, to use another word, i.e, large volume and long length tubing reduces friction while creating a steady air velocity?
wrecking 9/97 EL fairmont sedan burgundy 6cyl auto 270k modBAintake
Posted: Tue Apr 01, 2008 9:38 am
Ride: '06 BF GT-P
Power: 293 rwkw
It's been proven a few times, that a larger intake system can provide tangible benefits.
Most obvious of late has been the BluePower airbox for B series XR8's and GT's. It corners off the front left corner of the engine bay as the air box, with a large pod filter installed in place of the panel filter. Owners are reporting huge gains (20+RWKW). I've recently upgraded to one, but haven't had it dyno'd again.
On my EL replacing the plastic pipe from airbox to TB with a 3" mandrel bend pipe was a significant inprovement across the rev range, however on a less modified car, the improvement wasn't worth the outlay for the pipe.
Posted: Tue Apr 01, 2008 12:04 pm
Gallery: 18 images
Ride: Envi EF
Theres a fella that makes them like the pic EL Fairmont posted up, except far neater. Cant remember who tho...
>>>{DESCRIPTION}<<<
Users browsing this forum: No registered users and 52 guests
It is currently Thu Jun 19, 2025 7:56 pm All times are UTC + 11 hours
