Changing fuel pumps (wagon)
Page 1 of 1 [ 13 posts ]
 Post subject: Changing fuel pumps (wagon)
Posted: Wed May 28, 2008 7:16 pm
Ride: EDL Fairmont Wagon/AU XR8 Ghia
Hi all
My replacement list for my new ED continues. The fuel pump is making a cool high pitched whining noise so I need to replace it.
First up, I have an MPFI pump out of a 90 EA S - will that do?
Second, do I need to completely drain the fuel tank to do the wagon pump replacement? If so, what is the best way to do it?
Any help appreciated
RD
=1994 ED Wagon GLi body/EL Fairmont spec with *ALL* EL running gear.=
Build Thread: viewtopic.php?f=53&t=65695
=1998 EL Futura Sedan - The EF Fairmonts Replacement=
Build Thread: viewtopic.php?f=53&t=106588
Posted: Wed May 28, 2008 7:23 pm
Ride: No Fords current
Pretty sure the pump is the same from EA to EL on the MPFI models.
I just opened the fuel pump access hole and let it drain from there into a funnel and jerry - I couldn't see any drain plug or anything (but then my tank is cut down).
Hardest thing I found was getting the pump out of the tank, the fuel sender unit is long and squiggly, and kept fowling on the leaf springs, ended up putting a couple hundred killos (including me, my mate, my 65kg dog, and some barrels of water) to lower it to a point that it would easily slip in and out.
The most annoiying thing is getting the fuel lines off.
Posted: Wed May 28, 2008 7:26 pm
Gallery: 9 images
Ride: 02 xls ute 347
you dont need to drain the tank
02 series 3 AU marline ute 5speed 347 stroker
Posted: Wed May 28, 2008 7:33 pm
Thanks guys
My tank is currently between the red line and 1/4, or so the gauge says. Thanks too for the heads up on extracting the pump and fuel lines - oh joy, more barked knuckles to look forward to! :)
RD
Posted: Wed May 28, 2008 8:05 pm
a 65kg dog??? wtf thats a horse not a dog
RIP SCOTT
Posted: Sun Jun 01, 2008 10:58 pm
Alrighty
I am ready to change the fuel pump tomorrow and have been under the wagon looking. I hope I am blessed with an easy fuel line removal as I have the quick release joiners on the ED.
I do have a question: the outer ring on the wagon is vastly different from a sedan. Is the wagon one more like catch system than a rotating ring? For example, do you turn the pump/sender assembly to unlock it from the mount? Any tips appreciated..
RD
Posted: Sun Jun 01, 2008 11:46 pm
Alrighty
RD
The quick release hose joiners are the problem of why the fuel lines are a pain in the a***.
As for the ring, I used a chisel and hammer to turn it. Then remove the ring, then work the fuel level sensor and pump unit out.
Posted: Mon Jun 02, 2008 12:19 am
Thanks for that. So the quick connecters are that only in name huh? Should be interesting.
Hopefully the rain clears before tomorrow, I don't have a garage to use so it will all be done in the driveway - and it is raining in my part of NSW at the moment :(
RD
Posted: Mon Jun 02, 2008 10:34 am
Ride: AU XR8
as far as i know the wagon pump is different to sedan??
but you can use any mpfi pump from a wagon..
Posted: Mon Jun 02, 2008 10:48 am
Thanks for making me look Troyman. I remembered asking this question on my own forum and here is what I got:
"just looked up the Bosch cattledog, All sedans EA-EL with MPI use same pump, EA and EB wagons use that pump as well, ED and after (9/93>) wagons use a differant pump."
That was all fine when I only had EA's & EB's but now I have an ED that changes everything. I don't have one of them so I am stuffed until I get some more dollars in. Bugger!!!
RD
Posted: Mon Jun 02, 2008 11:37 am
I would be pulling it out still and comparing it to the the earlier one. Just because the part number is different, doesn't mean it won't fit or work.
BenJ
{DESCRIPTION} - Current Ride
{DESCRIPTION} - Previous Ride
Posted: Mon Jun 02, 2008 12:02 pm
Good call Ben
I'll do that on Wednesday. The car has to be mobile at least this afternoon to pick up the kids from school. From Wednesday on I can leave them to the bus so will take a look then.
RD
Posted: Mon Jun 02, 2008 12:29 pm
Whoa! I just phoned Winford and they didn't really know what the difference was. Was quoted $368.00 for a new pump - OUCH!
WIll find out in a day or two if they are infact different. The current pump got me from the North coast to here so it should get me around locally for another couple of days. I'll just have to ignore that whirring sound from the tank :)
RD
Users browsing this forum: No registered users and 65 guests
It is currently Fri Jun 06, 2025 2:14 am All times are UTC + 11 hours
