glenneaux |
hi all
Whats my best bet for engine rebuild? i mean total rebuild minus replacing pistons, ie bearings, rings, and the complete gasket set. ACL? through repco or somesuch?? |
Shortshift |
If you're getting an engine rebuilder to check, machine and assemble the block, they can probably get the parts cheaper than if you buy & supply them.
glenneaux |
i'd be reassembling it myself, its just a stock engine built with stock parts, no machining or anything.
Steady ED |
Bores will need a hone at the very least Glenn, thats if they are still good.
I'd probably get the deck skimmed too, just to give AU MLS headgasket 100% surface to seal on.
Users browsing this forum: No registered users and 73 guests |
