Genie/Wildcat extractors - the differences?
Page 1 of 1 [ 14 posts ]
 Post subject: Genie/Wildcat extractors - the differences?
Posted: Sun Apr 06, 2008 10:43 pm
Ride: No Fords current
Anyone got any ideas about the differences between the various Genie and Wildcat extractors?
They're all Tri-Y with the same size primaries and secondaries.
You've got the Genie 694E and the 694SS which are the same, just 1 is stainless steel. Then there is the Wilcat 21, 21X (has 1 1/2" primary pipes), 243 and 21SS (stainless steel version of the first ones).
Then you've got the Genie 694ELB which is just the Genie 694's with longer secondary pipes.
And finally there is the Genie 692E and Wilcat 21 or 243 which are the same things, supposebly, but why is the Wildcat 21 and 243 listed in both as being the same?
Posted: Sun Apr 06, 2008 10:50 pm
Ok, figured out the difference between Wildcats and Genies:
"ildcat headers are also made here at Genie. Wildcat headers are made to the same standard as our Genie range, but are produced with press bends or crush style bends ,where as Genie are a Full Mandrel bent made header. Wildcat covers a large range of replacement manifold applications, as well as the more budget priced performance market."
So, now I'm just interested in the difference between the Genie 694E and 692E - both have the same size Primary and Secondary pipes, both are Tri-Y.
Posted: Sun Apr 06, 2008 11:43 pm
Ride: MCMXCV Falcon
have you considered pacemakers?
Posted: Fri Aug 29, 2008 5:50 pm
Gallery: 18 images
Ride: XW, EL, Territory, VFR800
Power: 129 rwkw
Just digging this thread up a little...
I better hope you're wrong twr7cx... I just bought a set of Wildcat extractors off ebay new. And the ad said they were fully mandrel bent... Where did you get that info from?
EF GT6 - 129.4rwkw - Feautured in Street Fords Issue #77
XW GT Replica
Posted: Fri Aug 29, 2008 8:21 pm
From looking at there website i would say the 692E are 1 piece header like pacemaker and the 694E are a 2 piece design with an adaptor plater after the primary pipes?
97 EL Fairmont 4l OHC .Silver.
Exhaust: Pacemaker's, 2.5" exhaust and Hiflow cat
Intake: FRAM AIRHOG , EL GT snorkel
XR6 300kpa fuel reg Stg 2 Auto Shift Kit.6DJA ECU
PM in Qld looking too buy Toyota 4*4 SR5 Dualcab Hilux 91-97 with 2.8l diesel engine/5spd manual
Posted: Fri Aug 29, 2008 9:21 pm
Gallery: 5 images
Ride: AU Fairmont I6
A little.......its over 2 years old :roll:
Ford Fairmont AU
www.aufalcon.com/{DESCRIPTION}
Posted: Fri Aug 29, 2008 9:53 pm
Gallery: 18 images
Power: 129 rwkw
Try two months old...
XW GT Replica
Posted: Fri Aug 29, 2008 10:14 pm
Gallery: 5 images
oops lol :lol:
Ford Fairmont AU
Posted: Fri Aug 29, 2008 10:26 pm
Was just thinking the same thing!
Posted: Sat Aug 30, 2008 12:20 am
Ride: g6e 2009
im also running wildcat extractors on my ba, the exhaust shop dude told me they were mandrel...
Posted: Sat Aug 30, 2008 12:21 am
Gallery: 18 images
Power: 129 rwkw
Here's hoping or I'm gonna be s**t...
XW GT Replica
Posted: Sat Aug 30, 2008 5:39 pm
Genie website.
In the end I decided to stick with my Pacey comps as it turned out they were thelargest total diameter setup which is what I was after.
Posted: Sat Aug 30, 2008 7:11 pm
Ride: BFII Turbo
Power: 253 rwkw
from what I can recall wildcats are indeed crush bent, and are good for 0-3000 rpm torque. not much chop up high, better than stock (anything is really...)
enough isn't enough
Posted: Tue Sep 30, 2008 11:21 pm
so pacey comp headers are def. better than genie/wildcat headers? woudlnt larger diameter mean less tourque?
"I believe that Human beings and fish can peacefully coexist" - George W Bush
Users browsing this forum: No registered users and 73 guests
It is currently Mon Jun 09, 2025 5:25 am All times are UTC + 11 hours
