daniel000 |
Hi everyone got a 95 EF Fairmont an the other day just hopped in the car for a drive an as i started it, an as it started the revs dropped straight away an the car just stalled
then the 2nd time i tried to keep the revs up an the car was still on but then it was like it back fired anyone no what it could be thx |
daniel000 |
bump
daniel000 |
anyone had this prob?
SgtBourne |
could be a few things,
the fuel filter could be severly clogged, the injectors could be clogged. Does it crank over easily enough? if so, i would say that ignition is fine (ie spark etc) but could be worth checking out leads and spark plugs to see that they are in good nick. That's a starting point
_________________ So much RAM the motherboard twisted off the POST. |
daniel000 |
yeah it kicks over fine, jus as soon as it starts it cuts out,
could it be a sensor that has gone ? |
Rick's EF Fairmont Wagon |
hose popped off the Map sensor
_________________ BF3 Egas XT Wagon |
daniel000 |
thx, where abouts could i find the map sensor
Saiken |
Its on the side of the intake manifold
see the picture ![]()
_________________ Cobra Motorsports |
Saiken |
some times they come off, it was such a big problem that in the EL's they mounted the MAP's on the intake manifold instead.
daniel000 |
with my pic below wat is in the red that i hav drawn
fiftyone |
idle speed control
daniel000 |
ah k well we got the racv bloke to come around an the last thing he did was disconect that then reconect it, we just left the car as is, then the next day i tried starting it
and what do u no it started fine, jus now most times i go to start it it just cuts out an then the 2nd time it starts fine |
bushman |
well now thats a pickle
_________________ THE LOOSEST MUTHA FUKA YOU'VE EVER MET |
daniel000 |
yep i just changed the rev limiter module an yeh still doesnt help
no idea wat to do |
daniel000 |
or that idle speed control module
Users browsing this forum: Google Adsense [Bot], greywolf and 56 guests |
