Running without an ECU
Page 1 of 1 [ 8 posts ]
 Post subject: Running without an ECU
Posted: Tue Nov 25, 2008 6:15 pm
Hi everyone,new member here.Looks to be a great site with plenty of good info.My ride is a 96 ef Farimont Ghia,factory Tickford enhanced,only alteration is a mandrel bent 2.5 exhaust and extractors.Now my question.
I want to put an el or ef 4.0 into an xd ute.I kow I can use an Aussie speed 4 barrel intake manifold.I also want to use the btre trans and don't want to run an ECU.WHAT MODS AM i LOOKING AT TO ACHIEVE THIS.All help appreciated.
Posted: Tue Nov 25, 2008 6:23 pm
Ride: BA XR8
I am pretty sure it will slot in with XF mounts or maybe the EL/EF ones...K-frame clearance is not an issue i think. Should be pretty straight forward......
Why not use the ecu and EFI??? Pretty sure an engineer will tell you you have to, unless engineers cert' isnt necessary, cause it ford 6 replacing ford 6.....i would do some research before you start, dont want any nasty surprises!!!
8-) Daz 8-)
BA XR8 Boss 260
DAZFAB......Now Mobile
Mink = GAY
DAZFAB MEMBERS ,,,,DA22LE, XTT909, TERRORISTGHIA, TROYMAN, SWC, FAT245
Posted: Tue Nov 25, 2008 6:27 pm
Thanks Da22le,
Just to clarify no cert is needed and I do not want run an ECU.I figure if I can trick the BTRE somehow I am almost there.
Posted: Tue Nov 25, 2008 7:32 pm
Ride: AUII XR6 Uterus
pretty sure you can get standalone trans controllers from the people (or associates) that make tweecers.
Posted: Tue Nov 25, 2008 8:35 pm
Gallery: 9 images
Ride: Blue and White Mercedes
Didn't the EA's that had the 4 speed have the seperate controller under the seat??
Remember kids, the more pages of crap in your build thread, the bigger your e-penis is
Posted: Tue Nov 25, 2008 8:54 pm
Ride: 66 Coupe
to use the BTR, you will need an EA/EB trans control module, and fit a TPS to your carb, you will also need to run an electronic ignition along the lines of an MSD / CRANE etc so you get a square wave output to feed the TCM. All in all, your better off using the EL ecu (ie keep it injected) with a smartlock bypass module. Much more fuel efficient and will be easier in respect to running the auto, and ignition (the ecu also controls the timing, unless you use an XD style dissy)
Posted: Tue Nov 25, 2008 9:10 pm
or use the 3 speed with a kickdown cable. did 4 speeds come out with the cable ?
Posted: Tue Nov 25, 2008 9:47 pm
Fordmods Addict
Gallery: 13 images
Power: 237 rwkw
No, because the BTR is an electronically controlled box.
BF MKII F6 Tornado - 237rwkw
Users browsing this forum: No registered users and 66 guests
It is currently Fri Jun 06, 2025 12:25 am All times are UTC + 11 hours
