Weird, real bad miss only when turning.....
Page 1 of 1 [ 13 posts ]
 Post subject: Weird, real bad miss only when turning.....
Posted: Mon Dec 08, 2008 7:55 pm
Ride: EDL Fairmont Wagon/AU XR8 Ghia
Howdy
Today I installed lows in my wifes EB. Went for a drive to settle them in and all went well. Parked it, got changed and went back out when all of a sudden turning either direction from straight would result in some serious engine miss, just like it was running on 3 cyls. Thinking it may be fuel, I nursed it to the gas station as chucked $20.00 in. No difference - straight line fine, turn a corner and the missing takes over until I am straight again.
Does anyone have any idea what the hell might be going on? I can replicate it sitting in the driveway by just turning the wheel and trying to rev when in park....
RD
=1994 ED Wagon GLi body/EL Fairmont spec with *ALL* EL running gear.=
Build Thread: viewtopic.php?f=53&t=65695
=1998 EL Futura Sedan - The EF Fairmonts Replacement=
Build Thread: viewtopic.php?f=53&t=106588
Posted: Mon Dec 08, 2008 8:10 pm
Power steering pressure switch not working.
Posted: Mon Dec 08, 2008 8:13 pm
Hmmm, that would cause the miss? If it turns out to be that I will change it when I do the engine/trans as I have another rack going in at the same time....
Posted: Mon Dec 08, 2008 10:23 pm
I see how it could be the PS switch not sending the right signals to the ECU. Would just the act of installing lows into the front suspension put an extra load on the power steering causing an old switch to fail? This car is pretty tired so I wouldn't be surprised....
Posted: Tue Dec 09, 2008 9:40 am
Uh oh... I suspect the engine might have given up the ghost. It has had a rumble in the bottom end for a while and would blow smoke under accel. When it goes into this missing mode, blue smoke cascades out the back. I did try the car this morning and the miss (read 2 or 3 cyls running) appeared without turning anything. It cleared, backed it down the driveway (sloping) and tried to drive away. No go, 2 or 3 cyls only and lotsa smoke....
Time for that engine change me thinks....
Posted: Tue Dec 09, 2008 10:42 am
Ride: 66 Coupe
map sensor hose could be cracked / split, or also a bad earth to the engine block
Posted: Tue Dec 09, 2008 11:07 am
Well it seems you were on the right track. I just replaced the map sensor with one out of my donor EB and it seems to have fixed it. Well, at least I am able to drive around the corner and back on all 6 cylinders. Am a bit wary of going any great distance but will try a little further (somewhere not far to walk back from :)) to double check.
Posted: Tue Dec 09, 2008 11:11 am
Gallery: 30 images
Ride: xd 351, AUII XR6.... R.I.P ef fa
Is it dual fuel?.. has it got LPG... i had a lpg on me clevo.. it used to do that
<a href="http://s154.photobucket.com/albums/s278/stephen351/?action=view¤t=resize2.jpg" target="_blank"><img src="http://i154.photobucket.com/albums/s278/stephen351/resize2.jpg" border="0" alt="resize"></a>
Posted: Tue Dec 09, 2008 11:18 am
Nope, straight petrol. I am surprised the map sensor just up and died between runs, one minute it was working fine, next minute running on 3 cyls. Really strange.....
Posted: Tue Dec 09, 2008 3:20 pm
Gallery: 30 images
i got a EF map sensor there.. $10 if you want it.. but find out if it fits your car..
Think i spoke to you before... im out at penrith...
The map sensor is brand new..
Posted: Tue Dec 09, 2008 3:30 pm
Thanks matey but I got one out of my spare EB. Just went up to McGraths Hill with no problems at all so everythng seems to be fine.
Yup, we have spoken before, it was to do with your car. Still considering some bits if you still have it :) Gotta decide what I really need.
RD
Posted: Tue Dec 09, 2008 4:57 pm
Gallery: 30 images
yeah she still there.. gear box gone now...
Interior still perfect
Posted: Fri Dec 12, 2008 11:18 am
Ahhhhhhhhhhhhhh! It's back intermittently. Every now and again it happens when turning left only. Total pain in the butt and really starting to piss me off now.
Users browsing this forum: Facebook [Bot] and 64 guests
It is currently Fri Jun 06, 2025 8:09 pm All times are UTC + 11 hours
