Where do the I6's make maximum power?
Page 1 of 2 [ 30 posts ] Go to page 1, 2  Next
 Post subject: Where do the I6's make maximum power?
Posted: Thu Apr 21, 2005 10:22 pm
Ride: EL Futura
As i've posted, I had my car dynoed on Monday. As my car is a manual, and they ran it in 4th gear, she hit the speed limiter before the power backed off.
Going for a bit of a run on a private road of course, i discovered that the speed limiter happens at around 4900rpm in 4th. So my question is to you other guys with I6's that have been dyno'ed.. what is the range that your cars make peak power. I'm thinking that there could of been a couple of more kw in her before the fun limiter kicked in. :)
5 Speed EL Futura
Stock as a rock*
A1 Oils - Synthetic lubricants: www.a1oils.com.au
* A rock that has been Alted
Posted: Thu Apr 21, 2005 10:37 pm
Gallery: 36 images
Ride: Ronald Mcdonald Mobile
i didnt think manuals had speed limiters?
well saying that i was in a certain sydney members silver EB wagon last night doing 190km/h down the M5 giving a wave to some P platers in a Pulsar GTIR as we streamed past them :)
sorry Rob it was a funny moment i wish i got a picture of it :)
Gooooone - Eb2 Coon - 143RWKW
Now - Mazda MX5 with HKS Supercharger 190RWKW
Crescent Motorsport Liverpool - 9600 6229
Ride: FG II G6E TURBO
O.k. there seems something wrong here,manuals shoudlnt be speed limited and so my guess would be that it either has a auto ecu in it or somethinfg is wrong
Posted: Thu Apr 21, 2005 10:54 pm
Gallery: 24 images
Ride: BF MKII XR6 Turbo
I thought the auto's were speed limited not manuals? ne way my XR6 (auto) hit peak power at 108kph, not sure about what the RPM was at but im guessin it was at the limiter in 2nd gear mabe. :?
Image -BF MKII XR6 Turbo in EGO-
Posted: Fri Apr 22, 2005 12:53 am
Ride: EL Futura
All Non XR's had speed limiters, regardless of auto or manual. My car ISN'T an XR6.
It is a factory manual and has a manual ECU, and nothing is wrong.
The reason for the speed limiter wasn't due to the box (AFAIK it was either the auto XR6 or Auto XR8 was also speed limited) but due to the tail shaft falling apart at these high speeds. The XR's had a single piece (??) shaft and were alloy, and could withstand the higher speeds.
5 Speed EL Futura
Stock as a rock*
Posted: Fri Apr 22, 2005 12:54 am
Ride: No Fords current
I thought all the non-Tickford cars were speed limited (regardless of tranny type) because they wern't capable of over 180, were the Ticky's got a different tailshaft and what not which is why they're not limited
Posted: Fri Apr 22, 2005 1:06 am
Ride: BA Falcon EGas
Well b4 I modified mine i got it to 195 kms in the country. No sign of computer kicking in...Sucked slowing back down to make a turn tho. I missed it by about 30m!
BA Falcon Futura on EGas. Stock as...
EF 5 speed manual; PH 4480 Pacemaker Headers; 2 1/2" Lukey Mandrel Bent System; Hi Flow Walker Cat; Stage 3 Crow Cam; ChipTorque Chip; 3" Mandrel Bent Intake; K&N Pod Filter; Low Pedders Suspension; 17" EL GT Champagne Rims; RPM Series Clutch
Posted: Fri Apr 22, 2005 1:10 am
Ride: EL Futura
that would be correct
5 Speed EL Futura
Stock as a rock*
Posted: Fri Apr 22, 2005 1:14 am
So can you explain what happened when i got mine to 195?
Ride: 80 series cruiser
prehaps they changed in the ef el range, cause i know of a few eb ed that can exceed 180, my manual does, and my old xr8 auto did too, both eb's.
hey redgie, who was being silly on the m5?????????
Thanks to Crescent Motors, Liverpool.
Call Joe on (02) 9600 6229.
I dont own a Landcruiser, it's a Maverick recovery vehicle!!!!
Posted: Fri Apr 22, 2005 1:19 am
Ride: EL Futura
you may be right with the eariler models. My knowledge is limited to EF/EL. It was only recently that i learned the EB I had a 3.9L in it!
5 Speed EL Futura
Stock as a rock*
Posted: Fri Apr 22, 2005 1:25 am
E-AU series generally made peak power from 4750 to 4900rpm or in the XR6 about 5000rpm. peak torque 3000rpm or 3150rpm in the XR6 and 3500rpm in the VCT.
Even mildly modded cammed street motors usually peak around 5000 to 5300rpm. With a cam and head work on a streetable motor the peak doesn't go much past 5300rpm it just holds on more strongly till the 5700rpm limiter.
Ford weren't entirely silly 3.23 diff manuals will peak in fourth just before the speed limit. Auto 3.23 in third 4900rpm at 180kmh. Its only the 3.08 diff auto cars geared to get the best economy for fleet buyers that were totally nobbled by the stupid gearing.
Posted: Fri Apr 22, 2005 1:28 am
Ride: EL Futura
edit: For some strange reason I thought i had a 3.25 diff.. but it appears to be a 3.23. i'll check it tomorrow
5 Speed EL Futura
Stock as a rock*
Posted: Fri Apr 22, 2005 1:29 am
Gallery: 5 images
Ride: EL XR6
Aren't EF/EL XR's both manual and auto speed limited to 255kph? For some reason that sticks in my mind. Thats if you can get one that high :P
Posted: Fri Apr 22, 2005 2:04 am
Thats probably when you red-line 5th gear.
Not an actual speed limiter but a rev limiter.
That's just my guess.
Users browsing this forum: No registered users and 32 guests
It is currently Sat May 17, 2025 7:14 pm All times are UTC + 11 hours
