BoostedVT |
Age: 42 Posts: 490 Joined: 7th Jun 2010 Ride: Turbo VT, VL Calais Trubo, HQ SS Location: Melbourne |
Hi guys,
I just fired up my el after a few weeks and noticed there is a ticking noise coming from the front. Anyone know how to get rid of it? Thanks in advance. |
79 raven |
Sounds like maybe noisy tappets. after she has ran for a while does it go away? When was the last oil change done?
SWC |
If it has been sitting for a few weeks then the HLA's may have drained down, should clear up after a few minutes running.
Raven - EL's don't have tappets, they are OHC with HLA's. |
79 raven |
Thanks for the correction ye of extensive knowledge
BoostedVT |
I havent started the car in 4mths. I only let it run for around 5mins and the nosie was still there when I turned the car off.
I will take it out for a cruise later this week and see if it goes away after some driving. Thanks for the help guys. (An oil change was done around 9mths ago) but since the car has only done 90kms. |
EF_wanabe |
{USERNAME} wrote: I havent started the car in 4mths. I only let it run for around 5mins and the nosie was still there when I turned the car off. I will take it out for a cruise later this week and see if it goes away after some driving. Thanks for the help guys. (An oil change was done around 9mths ago) but since the car has only done 90kms. I guess the oil drained out as mentioned above but it should come back up in around 5mins of idling though Hopefully it goes away while driving Also sorry to take it OT , but is it true the 5L V8 HLA's will fit the 6s ? |
SWC |
{USERNAME} wrote: {USERNAME} wrote: I havent started the car in 4mths. I only let it run for around 5mins and the nosie was still there when I turned the car off. I will take it out for a cruise later this week and see if it goes away after some driving. Thanks for the help guys. (An oil change was done around 9mths ago) but since the car has only done 90kms. I guess the oil drained out as mentioned above but it should come back up in around 5mins of idling though Hopefully it goes away while driving Also sorry to take it OT , but is it true the 5L V8 HLA's will fit the 6s ? I can take a few hours some times for the HLA's to pump up properly. 5.0L Windsor don't have HLA's, they have Hydralic Lifters, They have no chance of fitting a SOHC 6. |
EF_wanabe |
{USERNAME} wrote: {USERNAME} wrote: {USERNAME} wrote: I havent started the car in 4mths. I only let it run for around 5mins and the nosie was still there when I turned the car off. I will take it out for a cruise later this week and see if it goes away after some driving. Thanks for the help guys. (An oil change was done around 9mths ago) but since the car has only done 90kms. I guess the oil drained out as mentioned above but it should come back up in around 5mins of idling though Hopefully it goes away while driving Also sorry to take it OT , but is it true the 5L V8 HLA's will fit the 6s ? I can take a few hours some times for the HLA's to pump up properly. 5.0L Windsor don't have HLA's, they have Hydralic Lifters, They have no chance of fitting a SOHC 6. Ah ok fair enough , ive just heard some where some type of other ford V8 engine there HLA's fit |
Users browsing this forum: No registered users and 41 guests |
