remove air con belt on 89 EA???
Page 1 of 1 [ 7 posts ]
 Post subject: remove air con belt on 89 EA???
Posted: Thu Feb 19, 2009 10:36 pm
Ride: 95 EF XR8 & a 09 FG GT
hey all, I am trying to remove the air con belt on a 89 EA Falcon 3.9 lr CFI model car, how on earth do you do it?, I removed the idle tension pully for it but it seems impossible to remove the belt?? there is nothing else I can find to release tension, I remember I could not get it on, some one else done it, but have no idea how it was put on, but now I cant remove it any ideas??, and no idiot comments please, i.e don't tell me to cut it.......
urgent reply if possible, thanks for the help...
Aaron
 Post subject: Re: remove air con belt on 89 EA???
Posted: Thu Feb 19, 2009 11:01 pm
Ride: VY Commodore Wagon Accli
on the Idle Tensioner there should be 2 sets of nuts, a small one and a big one, the big one is about a 24mm socket, I use a spanner, turn that anti-clockwise and it should come off.
I have an ED, so I don't think much would have changed on the aircon from your model to mine, but someone else with a 3.9 CFI EA might be able to comfirm...
Successful Trades with: John_XR6 (John_LS1), Private9, Schmee, Manari, Kyle_Bardell, Greenhorn (Boostedfalcon.net), FTG AUTO SALVAGE, EVL098, Gogetta, EFIII, Krytox, Blue, Smik-EL, TP351.
Posted: Thu Feb 19, 2009 11:20 pm
yeah mate ive done that already the idle pully is completely off, I can't get the belt over the crank or air con compressor to get it off at all its as if the belt is too small or shrunk but im sure thats impossible???
Posted: Fri Feb 20, 2009 11:23 am
Take some photo's of it, it will help us see exactly what the problem is, it sounds like the belt itself is too small....
Posted: Mon Feb 23, 2009 10:16 am
yer thats what I thought too mate, i got one that actually was too small, so i got another one the right part number, but I did not put it on, but now it seems like it is too small and won't come off, even if it was too small, then I don't think it would fit on at all to begine with???
its got me stuffed aye..
Posted: Mon Feb 23, 2009 10:47 am
So if I'm thinking correctly, with the idler pulley completly off, the belt is that tight that it doesn't look as if it needs the idler pulley at all???
Do you know what model Air Con you have attached to that car??? might be worth a pic or 2 of the belt, and the aircon.
Posted: Mon Feb 23, 2009 12:01 pm
Just cut it off. You're also going to need to remove the other two belts in order to get the new one on.
Users browsing this forum: Google Adsense [Bot] and 66 guests
It is currently Sun Jun 08, 2025 7:08 am All times are UTC + 11 hours
