Bottom End Rebuild.
Page 1 of 1 [ 9 posts ]
 Post subject: Bottom End Rebuild.
Posted: Thu Apr 14, 2005 8:08 am
I am rebuilind the bottom end on my new mtoro shortly.
3.9Ltr MPFi
I am going to bore it out 60 thou.
Does anyone know if you can get a crank out of any motor that by putting it in would give it a bigger stroke.
e.g. i think with 202's you can put in a ford crank and the stroke is increased aka more HP :D
BAG 17
 Post subject: Re: Bottom End Rebuild.
Posted: Thu Apr 14, 2005 9:42 am
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
3.9Ltr MPFi
The stroke of these engines is already ridiculously long, and physically can't be made any longer. Already begged several workshops to do a custom crank for me.. its a no go!
Posted: Thu Apr 14, 2005 11:17 am
Power: 482 rwkw
Exactly....Actually the 3.3 makes a VERY good strong engine when turbo'd..With good valve gear etc, they rev to the moon...
A slightly shorter stroke would help the 4.0 also...By offset grinding the big end bearings..Capacity would be reduced though....
As in ZOOM 126 edition
Posted: Thu Apr 14, 2005 1:40 pm
Ride: BA ute, FG XR6T
I think you make a very good point here. The 3.3 in a Multi-point / Turbo setup would appear at least on paper to have some unexplored potential IMO.
Posted: Thu Apr 14, 2005 3:10 pm
Ride: 2005 Hi-Ace
dont think you can go up 0.060" on a 3.9/4.0L. the most is 0.040".
i would want to keep it at most 0.020" as the bigger you go the more it can run too hot.
i know that you can run AU rods and pistons in any 3.9/4.0L as the big end journal size on the cranks are all the same.
2005 Toyota Hi-Ace aka ICE CUBE
Posted: Thu Apr 14, 2005 3:40 pm
Ride: BA Fairlane Ghia
the 215 cube donk the used to be in Valiants, was good for hi-po mods, due to it being a square bore, as Waggin said, stroke is alredy to long, vibrations/harshness would increase to i reckon.
Posted: Thu Apr 14, 2005 3:42 pm
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
.060 is fine, and doesnt run too hot.. not even at 11.7:1 compression :)
The only thing that got hot last night on the dyno was the extractors.. basically see-thru red :)
Posted: Fri Apr 15, 2005 10:03 am
hey waggin do you have forged pistons'/ how much they cost?
BAG 17
Posted: Fri Apr 15, 2005 1:40 pm
Site Admin
Ride: AUII V8 LTD
Power: 270 rwkw
Yes, I do.
Call around for prices on ACL forged.
It is currently Sat May 17, 2025 8:38 pm All times are UTC + 11 hours
